《Linux Host Utilities 7.1命令参考》
贡献者
您可以使用Linux Host Utilities 7.1示例命令参考、通过Host Utilities工具对NetApp存储配置进行端到端验证。
列出映射到主机的所有主机启动程序
您可以检索映射到主机的所有主机启动程序的列表。
# sanlun fcp show adapter -v
示例输出
adapter name: host15 WWPN: 10000090fa022736 WWNN: 20000090fa022736 driver name: lpfc model: LPe16002B-M6 model description: Emulex LPe16002B-M6 PCIe 2-port 16Gb Fibre Channel Adapter serial number: FC24637890 hardware version: 0000000b 00000010 00000000 driver version: 12.8.0.5; HBAAPI(I) v2.3.d, 07-12-10 firmware version: 12.8.340.8 Number of ports: 1 port type: Fabric port state: Operational supported speed: 4 GBit/sec, 8 GBit/sec, 16 GBit/sec negotiated speed: 16 GBit/sec OS device name: /sys/class/scsi_host/host15 adapter name: host16 WWPN: 10000090fa022737 WWNN: 20000090fa022737 driver name: lpfc model: LPe16002B-M6 model description: Emulex LPe16002B-M6 PCIe 2-port 16Gb Fibre Channel Adapter serial number: FC24637890 hardware version: 0000000b 00000010 00000000 driver version: 12.8.0.5; HBAAPI(I) v2.3.d, 07-12-10 firmware version: 12.8.340.8 Number of ports: 1 port type: Fabric port state: Operational supported speed: 4 GBit/sec, 8 GBit/sec, 16 GBit/sec negotiated speed: 16 GBit/sec OS device name: /sys/class/scsi_host/host16
列出映射到主机的所有 LUN
您可以检索映射到主机的所有LUN的列表。
# sanlun lun show -p -v all
示例输出
ONTAP Path: vs_sanboot:/vol/sanboot_169/lun LUN: 0 LUN Size: 150g Product: cDOT Host Device: 3600a0980383143393124515873683561 Multipath Policy: service-time 0 DM-MP Features: 3 queue_if_no_path pg_init_retries 50 Hardware Handler: 1 alua Multipath Provider: Native ----------- --------- ---------- ------- ------------ ---------- ---------- host vserver host: dm-mp path path /dev/ chan: vserver major: state state type node id:lun LIF minor ----------- --------- ---------- ------- ------------ ---------- ---------- active up primary sdq 15:0:5:0 lif_18 65:0 active up primary sds 16:0:5:0 lif_17 65:32 active up primary sdac 16:0:7:0 lif_25 65:192 active up primary sdad 15:0:7:0 lif_26 65:208 active up secondary sdt 15:0:4:0 lif_20 65:48 active up secondary sdr 15:0:6:0 lif_19 65:16 active up secondary sdad 16:0:4:0 lif_27 66:96 active up secondary sdan 16:0:6:0 lif_28 66:112
列出从给定 SVM 映射到主机的所有 LUN
您可以从特定Storage VM (SVM)检索映射到主机的所有LUN的列表。
# sanlun lun show -p -v vs_sanboot
示例输出
ONTAP Path: vs_sanboot:/vol/sanboot_169/lun LUN: 0 LUN Size: 160g Product: cDOT Host Device: 3600a0980383143393124515873683561 Multipath Policy: service-time 0 DM-MP Features: 3 queue_if_no_path pg_init_retries 50 Hardware Handler: 1 alua Multipath Provider: Native ----------- --------- ---------- ------- ------------ --------------- ---------- host vserver host: dm-mp path path /dev/ chan: vserver major: state state type node id:lun LIF minor ----------- --------- ---------- ------- ------------ --------------- ---------- active up primary sdce 15:0:5:0 lif_16g_5 69:32 active up primary sdfk 16:0:5:0 lif_16g_7 130:96 active up primary sdfm 16:0:7:0 lif_16g_8 130:128 active up primary sdcg 15:0:7:0 lif_16g_6 69:64 active up secondary sdcd 15:0:4:0 lif_16g_1 69:16 active up secondary sdcf 15:0:6:0 lif_16g_2 69:48 active up secondary sdfj 16:0:4:0 lif_16g_3 130:80 active up secondary sdfl 16:0:6:0 lif_16g_4 130:112
列出映射到主机的给定 LUN 的所有属性
您可以检索映射到主机的指定LUN的所有属性的列表。
# sanlun lun show -p -v vs_sanboot:/vol/sanboot_169/lun
示例输出
ONTAP Path: vs_sanboot:/vol/sanboot_169/lun LUN: 0 LUN Size: 160g Product: cDOT Host Device: 3600a0980383143393124515873683561 Multipath Policy: service-time 0 DM-MP Features: 3 queue_if_no_path pg_init_retries 50 Hardware Handler: 1 alua Multipath Provider: Native ----------- --------- ---------- ------- ------------ ----------------- ---------- host vserver host: dm-mp path path /dev/ chan: vserver major: state state type node id:lun LIF minor ----------- --------- ---------- ------- ------------ ----------------- ---------- active up primary sdce 15:0:5:0 lif_16g_5 69:32 active up primary sdfk 16:0:5:0 lif_16g_7 130:96 active up primary sdfm 16:0:7:0 lif_16g_8 130:128 active up primary sdcg 15:0:7:0 lif_16g_6 69:64 active up secondary sdcd 15:0:4:0 lif_16g_1 69:16 active up secondary sdcf 15:0:6:0 lif_16g_2 69:48 active up secondary sdfj 16:0:4:0 lif_16g_3 130:80 active up secondary sdfl 16:0:6:0 lif_16g_4 130:112
列出将给定 LUN 映射到主机的 ONTAP SVM 标识
您可以检索特定ONTAP映射到历史记录的LUN SVM标识的列表。
# sanlun lun show -m -v vs_sanboot:/vol/sanboot_169/lun
示例输出
device host lun vserver lun-pathname filename adapter protocol size product --------------------------------------------------------------------------------------------------------------- vs_sanboot /vol/sanboot_169/lun /dev/sdfm host16 FCP 160g cDOT LUN Serial number: 81C91$QXsh5a Controller Model Name: AFF-A400 Vserver FCP nodename: 2008d039ea1308e5 Vserver FCP portname: 2010d039ea1308e5 Vserver LIF name: lif_16g_8 Vserver IP address: 10.141.12.165 10.141.12.161 10.141.12.163 Vserver volume name: sanboot_169 MSID::0x000000000000000000000000809E7CC3 Vserver snapshot name:
按主机设备文件名列出ONTAP LUN属性
您可以按主机设备文件名检索ONTAP LUN属性列表。
# sanlun lun show -d /dev/sdce
示例输出
controller(7mode/E-Series)/ device host lun vserver(cDOT/FlashRay) lun-pathname filename adapter protocol size product ---------------------------------------------------------------------------------------------------- vs_sanboot /vol/sanboot_169/lun /dev/sdce host15 FCP 160g cDOT [root@sr630-13-169 ~]#
列出连接到主机的所有 SVM 目标 LIF WWPN
您可以检索连接到主机的所有SVM目标LIF WWPN的列表。
# sanlun lun show -wwpn
示例输出
controller(7mode/E-Series)/ target device host lun vserver(cDOT/FlashRay) wwpn lun-pathname filename adapter size product ----------------------------------------------------------------------------------------------------------------------- vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_8/lun /dev/sdlo host18 10g cDOT vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_9/lun /dev/sdlp host18 10g cDOT vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_7/lun /dev/sdln host18 10g cDOT vs_169_16gEmu 202cd039ea1308e5 /vol/VOL_8g_169_2_5/lun /dev/sdll host18 10g cDOT
列出给定 SVM 目标 LIF WWPN 在主机上看到的 ONTAP LUN
您可以检索指定SVM目标LIF WWPN在主机上发现的ONTAP LUN的列表。
# sanlun lun show -wwpn 2010d039ea1308e5
示例输出
controller(7mode/E-Series)/ target device host lun vserver(cDOT/FlashRay) wwpn lun-pathname filename adapter size product --------------------------------------------------------------------------------------------------------------- vs_sanboot 2010d039ea1308e5 /vol/sanboot_169/lun /dev/sdfm host16 160g cDOT
