Quick guide - ASA C400
- PDF of this doc site
Creating your file...
Your file is ready
The quick guide provides graphic instructions for a typical installation of your system, from racking and cabling, through initial system bring-up. Use this procedure if you are familiar with installing NetApp systems.
The ASA C400 uses the same installation procedure as the AFF C400 system. |
