Detailed steps - AFF 900
This article gives detailed step-by-step instructions for installing a typical NetApp system. Use this article if you want more detailed installation instructions.
Step 1: Prepare for installation
To install your system, you need to create an account on the NetApp Support Site, register your system, and get license keys. You also need to inventory the appropriate number and type of cables for your system and collect specific network information.
You need to have access to the NetApp Hardware Universe for information about site requirements as well as additional information on your configured system.
You might also want to have access to the ONTAP 9 Release Notes for your version of ONTAP for more information about this system.
You need to provide the following at your site:
Rack space for the storage system
Phillips #2 screwdriver
Additional networking cables to connect your system to your network switch and laptop or console with a Web browser
Unpack the contents of all boxes.
Record the system serial number from the controllers.
Inventory and make a note of the number and types of cables you received.
The following table identifies the types of cables you might receive. If you receive a cable not listed in the table, see the Hardware Universe to locate the cable and identify its use.
Type of cable… Part number and length Connector type For… 25 GbE data Cable
X66240A-05 (112-00639), 0.5m
X66240A-2 (112-00598), 2m
X66240A-5 (112-00600), 5m
Network cable
32 Gb FC (SFP+ Op)
X66250-2 (112-00342), 2m
X66250-5 (112-00344), 5m
X66250-15 (112-00346), 15m
FC optical network cable
40 GbE network cable
X66100-1 (112-00542), 1m
X66100-3 (112-00543), 3m
X66100-5 (112-00544), 5m
Ethernet data, cluster network
100 GbE cable
X66211B-1 (112-00573), 1m
X66211B-2 (112-00574), 2m
X66211B-5 (112-00576), 5m
Network,
NVME storage,
Ethernet data,
cluster network
Optical cables
X66031A (112-00436), 1m
X66032A (112-00437), 2m
X66033A (112-00438), 3m
FC optical network
Cat 6, RJ-45 (order dependent)
Part numbers X6585-R6 (112-00291), 3m
X6562-R6 (112-00196), 5m
Management network and Ethernet data
Micro-USB console cable
Not applicable
Console connection during software setup on non-Windows or Mac laptop/console
Power cables
Not applicable
Powering up the system
Review the ONTAP Configuration Guide and collect the required information listed in that guide.
Step 2: Install the hardware
You need to install your system in a 4-post rack or NetApp system cabinet, as applicable.
Install the rail kits, as needed.
Install and secure your system using the instructions included with the rail kit.
You need to be aware of the safety concerns associated with the weight of the system. -
Attach cable management devices (as shown).
Place the bezel on the front of the system.
The following diagram shows a representation of what a typical system looks like and where the major components are located at the rear of the system:
Step 3: Cable controllers to your network
You can cable the controllers to your network by using the two-node switchless cluster method or by using the cluster interconnect network.
Management network, data network, and management ports on the controllers are connected to switches. The cluster interconnect ports are cabled on both controllers.
You must have contacted your network administrator for information about connecting the system to the switches.
Be sure to check the direction of the cable pull-tabs when inserting the cables in the ports. Cable pull-tabs are up for all networking module ports.
As you insert the connector, you should feel it click into place; if you do not feel it click, remove it, turn it around and try again. |
Use the animation or illustration to complete the cabling between the controllers and to the switches:
Animation - Cable a two-node switchless clusterStep Perform on each controller Cable cluster interconnect ports:
Slot A4 and B4 (e4a)
Slot A8 and B8 (e8a)
Cable controller management (wrench) ports.
Cable 25 GbE network switches:
Ports in slot A3 and B3 (e3a and e3c) and slot A9 and B9 (e9a and e9c) to the 25 GbE network switches.
40GbE host network switches:
Cable host‐side b ports in slot A4 and B4 (e4b) and slot A8 and B8 (e8b) to the host switch.
Cable 32 Gb FC connections:
Cable ports in slot A5 and B5 (5a, 5b, 5c, and 5d) and slot A7 and B7 (7a, 7b, 7c, and 7d) to the 32 Gb FC network switches.
Strap the cables to the cable management arms (not shown).
Connect the power cables to the PSUs and connect them to different power sources (not shown). PSU 1 and 3 provide power to all side A components, while PSU2 and PSU4 provide power to all side B components.
Management network, data network, and management ports on the controllers are connected to switches. The cluster interconnect and HA ports are cabled on to the cluster/HA switch.
As you insert the connector, you should feel it click into place; if you do not feel it click, remove it, turn it over and try again. |
Animation - Cable a switched clusterStep Perform on each controller Cable cluster interconnect a ports:
Slot A4 and B4 (e4a) to the cluster network switch.
Slot A8 and B8 (e8a) to the cluster network switch.
Cable 25GbE network switches:
Step 4: Cable controllers to drive shelves
Cable either a single NS224 drive shelf or two NS224 drive shelves to your controllers.
You must cable each controller to the NSM modules on the NS224 drive shelf on an AFF A900 system.
Be sure to check the illustration arrow for the proper cable connector pull-tab orientation. The cable pull-tab for the storage modules are up, while the pull tabs on the shelves are down.
Use the following animation or drawings to cable your controllers to a single NS224 drive shelf.
Animation - Cable a single NS224 shelfStep Perform on each controller -
Connect controller A port e2a to port e0a on NSM A on the shelf.
Connect controller A port e10b to port e0b on NSM B on the shelf.
100 GbE cable
Connect controller B port e2a to port e0a on NSM B on the shelf.
Connect controller B port e10b to port e0b on NSM A on the shelf.
100 GbE cable
You must cable each controller to the NSM modules on the NS224 drive shelves.
Use the following animation or diagram to cable your controllers to two NS224 drive shelves.
Animation - Cable two NS224 shelvesStep Perform on each controller -
Connect controller A port e2a to NSM A e0a on shelf 1.
Connect controller A port e10b to NSM B e0b on shelf 1.
Connect controller A port e2b to NSM B e0b on shelf 2.
Connect controller A port e10a to NSM A e0a on shelf 2.
100 GbE cable
Connect controller B port e2a to NSM B e0a on shelf 1.
Connect controller B port e10b to NSM A e0b on shelf 1.
Connect controller B port e2b to NSM A e0b on shelf 2.
Connect controller B port e10a to NSM B e0a on shelf 2.
100 GbE cable
Step 5: Complete system setup and configuration
You can complete the system setup and configuration using cluster discovery with only a connection to the switch and laptop, or by connecting directly to a controller in the system and then connecting to the management switch.
If you have network discovery enabled on your laptop, you can complete system setup and configuration using automatic cluster discovery.
Use the following animation or drawing to set one or more drive shelf IDs:
The NS224 shelves are pre-set to shelf ID 00 and 01. If you want to change the shelf IDs, you must create a tool to insert into the hole where button is located. see Change a shelf ID - NS224 shelves for detailed instructions.
Animation - Set NVMe drive shelf IDsShelf end cap
Shelf faceplate
Shelf ID LED
Shelf ID setting button
Turn on the power switches on the power supplies to both nodes.
Animation - Turn on the power to the controllersInitial booting may take up to eight minutes. -
Make sure that your laptop has network discovery enabled.
See your laptop's online help for more information.
Use the following animation to connect your laptop to the Management switch.
Animation - Connect your laptop to the Management switch -
Select an ONTAP icon listed to discover:
Open File Explorer.
Click network in the left pane.
Right click and select refresh.
Double-click either ONTAP icon and accept any certificates displayed on your screen.
XXXXX is the system serial number for the target node. System Manager opens.
Use System Manager guided setup to configure your system using the data you collected in the ONTAP Configuration Guide.
Set up your account and download Active IQ Config Advisor:
Log in to your existing account or create an account.
Register your system.
Download Active IQ Config Advisor.
Verify the health of your system by running Config Advisor.
After you have completed the initial configuration, go to the ONTAP & ONTAP System Manager Documentation Resources page for information about configuring additional features in ONTAP.
If you are not using a Windows or Mac-based laptop or console or if auto discovery is not enabled, you must complete the configuration and setup using this task.
Cable and configure your laptop or console:
Set the console port on the laptop or console to 115,200 baud with N-8-1.
See your laptop or console's online help for how to configure the console port. -
Connect the console cable to the laptop or console using the console cable that came with your system, and then connect the laptop to the management switch on the management subnet.
Assign a TCP/IP address to the laptop or console, using one that is on the management subnet.
Use the following animation to set one or more drive shelf IDs:
Shelf faceplate
Shelf ID LED
Assign an initial node management IP address to one of the nodes.
If the management network has DHCP… Then… Configured
Record the IP address assigned to the new controllers.
Not configured
Open a console session using PuTTY, a terminal server, or the equivalent for your environment.
Check your laptop or console's online help if you do not know how to configure PuTTY. -
Enter the management IP address when prompted by the script.
Using System Manager on your laptop or console, configure your cluster:
Point your browser to the node management IP address.
The format for the address is https://x.x.x.x. -
Configure the system using the data you collected in the ONTAP Configuration Guide
