Install and maintain
Overview of boot media replacement - ASA C800
Contributors netapp-jsnyder
  • You must replace the failed component with a replacement FRU component you received from your provider.
  • It is important that you apply the commands in these steps on the correct controller:
    • The impaired controller is the controller on which you are performing maintenance.
    • The healthy controller is the HA partner of the impaired controller.
