Install and maintain
Overview of boot media replacement - AFF A700 and FAS9000
The boot media stores a primary and secondary set of system (boot image) files that the system uses when it boots. Depending on your network configuration, you can perform either a nondisruptive or disruptive replacement.
You must have a USB flash drive, formatted to FAT32, with the appropriate amount of storage to hold the image_xxx.tgz.
You also must copy the image_xxx.tgz file to the USB flash drive for later use in this procedure.
  • The nondisruptive and disruptive methods for replacing a boot media both require you to restore the var file system:
    • For nondisruptive replacement, the HA pair does not require connection to a network to restore the var file system. The HA pair in a single chassis has an internal e0S connection, which is used to transfer var config between them.
    • For disruptive replacement, you do not need a network connection to restore the var file system, but the process requires two reboots.
  • You must replace the failed component with a replacement FRU component you received from your provider.
  • It is important that you apply the commands in these steps on the correct node:
    • The impaired node is the node on which you are performing maintenance.
    • The healthy node is the HA partner of the impaired node.
