Shut down the impaired controller - AFF A220
- PDF of this doc site
Creating your file...
Shut down or take over the impaired controller using the appropriate procedure for your configuration.
Option 1: Most configurations
After completing the NVE or NSE tasks, you need to complete the shutdown of the impaired controller.
Take the impaired controller to the LOADER prompt:
If the impaired controller displays… Then… The LOADER prompt
Go to Remove controller module.
Waiting for giveback…
Press Ctrl-C, and then respond
y
when prompted.System prompt or password prompt (enter system password)
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name
When the impaired controller shows Waiting for giveback…, press Ctrl-C, and then respond
y
From the LOADER prompt, enter:
printenv
to capture all boot environmental variables. Save the output to your log file.This command may not work if the boot device is corrupted or non-functional.
Option 2: Controller is in a MetroCluster
Do not use this procedure if your system is in a two-node MetroCluster configuration. |
To shut down the impaired controller, you must determine the status of the controller and, if necessary, take over the controller so that the healthy controller continues to serve data from the impaired controller storage.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If you have a MetroCluster configuration, you must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state (
metrocluster node show
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=number_of_hours_downh
The following AutoSupport message suppresses automatic case creation for two hours:
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h
Disable automatic giveback from the console of the healthy controller:
storage failover modify –node local -auto-giveback false
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
y
y
