Confirm visibility of important objects
After adding a managed storage system, you should confirm that you can see all the important logical and physical objects in NetApp SMI-S Provider.
You can use the smis command to see the objects that are in the NetApp SMI-S Provider CIMOM repository. For example, use smis list to display added storage systems, and use smis luns to display LUN information.
