Enable or disable authentication for NetApp SMI-S Provider
By default, authentication is enabled for SMI-S Provider. If authentication causes errors on your system, you can optionally disable it. If authentication has been disabled and you want to reenable it, you can do so.
You must already have login credentials as Administrator.
You must already have logged in as Administrator.
Any client, including System Center Virtual Machine Manager (SCVMM), must be connected to the provider using cimuser and cimpassword.
Access NetApp SMI-S Provider.
Set the authentication for SMI-S Provider:
Action Command Enable authentication if previously disabled
cimconfig -p -s enableAuthentication=trueDisable authentication
cimconfig -p -s enableAuthentication=falseCIMOM does not use Windows authentication.
Restart NetApp SMI-S Provider:
smis cimserver restart
