Types of CIM users and associated operations
When using SMI-S Provider, there are various types of user that you can assign to a user to control their access to the CIM server.
Starting with this release, the Domain user is allowed to modify the SMI-S Provider user database and other configuration settings as a Domain user of the Local Administrators group.
The following table lists the supported users of the CIM server and the operations that each type can perform.
| Type of user | Operations |
Domain administrator of the Administrators group |
SMI-S Provider configuration and user management using
Storage management and verification using
SCVMM discovery operations using the SCVMM GUI. |
Domain user of the Local Administrators group |
Local user of the Local Administrators group |
Built-in Domain Administrator user |
Built-in Local Administrator user |
Domain user of the Users group |
Local user of the Users group |
If you have SMI-S Provider on a Windows host and changed any “Administrator” user name, you must log out of the system and then log back in. The SMI-S Windows Service inherits authentication during this time; as a result, any change to the credentials are not recognized until the administrator logs out and then logs in again. |
