NetApp SMI-S Provider
Cannot add a storage system using a nondefault HTTP or HTTPS port
You cannot add a NetApp storage system to NetApp SMI-S Provider when that system uses HTTP or HTTPS on a nondefault port. Add the storage system by specifying the nondefault port explicitly.
  • Issue
    You cannot add a storage system running HTTP or HTTPS on a nondefault port.
  • Cause
    By default, NetApp SMI-S Provider uses port 80 for communicating with storage systems over HTTP and port 443 for communicating over HTTPS.
  • Corrective action
    Use the following command to add a storage system that uses a port other than 80 for HTTP traffic or port 443 for HTTPS traffic:
    cimcli ci -n root/ontap ONTAP_FilerData hostName=storage_sys_ip_address port=non_default_port userName=storage_sys_user password=storage_sys_pwd comMechanism=HTTP -u agent_user -p agent_pwd-llocalhost:5989 -s
    -u, -p, -l, and -s are optional parameters.
Adding a storage system that uses port 8000 for HTTP traffic
cimcli ci -n root/ontap ONTAP_FilerData hostName=10.60.167.12 port=8000 userName=root password=netapp1! comMechanism=HTTP -u root -p netapp1! -l localhost:5989 -s --timeout 180
