NetApp SMI-S Provider
Required licenses
To use NetApp SMI-S Provider, you must have the required licenses.
The following licenses are required for NetApp SMI-S Provider:
  • FCP, iSCSI, or both FCP and iSCSI licenses are required for creating LUNs on the storage systems.
  • A CIFS license is required for creating file shares on supported ONTAP storage systems.
  • A FlexClone license is required to create LUN clones on clustered storage systems running supported ONTAP versions.
