Resynchronize a replication relationship
You need to resynchronize a replication relationship after you make a destination volume writeable, after an update fails because a common Snapshot copy does not exist on the source and destination volumes, or if you want to change the replication policy for the relationship.
Although resync does not require a baseline transfer, it can be time-consuming. You might want to run the resync in off-peak hours.
You must specify the Element source path in the form <hostip:>/lun/<name>, where “lun” is the actual string “lun” and name is the name of the Element volume.
Resync the source and destination volumes:
snapmirror resync -source-path <hostip:>/lun/<name> -destination-path <SVM:volume>|<cluster://SVM/volume> -type XDP -policy <policy>For complete command syntax, see the man page.
The following example resyncs the relationship between the source volume
0005at IP address 10.0.0.11 and the destination volumevolA_dstonsvm_backup:cluster_dst::> snapmirror resync -source-path 10.0.0.11:/lun/0005 -policy MirrorLatest -destination-path svm_backup:volA_dst
