Element Software
Cluster capacity in a mixed node environment
Contributors netapp-pcarriga netapp-yvonneo
You can mix different types of nodes in a cluster. The SF-Series 2405, 3010, 4805, 6010, 9605, 9010, 19210, 38410 and the H-Series can coexist in a cluster.
The H-Series consists of H610S-1, H610S-2, H610S-4, and H410S nodes. These nodes are both 10GbE and 25GbE capable.
It is best to not intermix non-encrypted and encrypted nodes. In a mixed node cluster, no node can be larger than 33 percent of the total cluster capacity. For instance, in a cluster with four SF-Series 4805 nodes, the largest node that can be added alone is an SF-Series 9605. The cluster capacity threshold is calculated based on the potential loss of the largest node in this situation.
Depending on your Element software version, the following SF-series storage nodes are not supported:
Beginning with…​ Storage node not supported…​
Element 12.8
  • SF4805
  • SF9605
  • SF19210
  • SF38410
Element 12.7
  • SF2405
  • SF9608
Element 12.0
  • SF3010
  • SF6010
  • SF9010
If you attempt to upgrade one of these nodes to an unsupported Element version, you will see an error stating that the node is not supported by Element 12.x.
