Element Software
Learn about SolidFire architecture
Contributors netapp-pcarriga netapp-dbagwell amgrissino
A SolidFire all-flash storage system is comprised of discrete hardware components (drive and nodes) that are combined into a pool of storage resources with NetApp Element software running independently on each node. This single storage system is managed as a single entity by using the Element software UI, API and other management tools.
A SolidFire storage system includes the following hardware components:
  • Cluster: The hub of the SolidFire storage system that is a collection of nodes.
  • Nodes: The hardware components grouped into a cluster. There are two types of nodes:
    • Storage nodes, which are servers containing a collection of drives
    • Fibre Channel (FC) nodes, which you use to connect to FC clients
  • Drives: Used in storage nodes to store data for the cluster. A storage node contains two types of drives:
    • Volume metadata drives store information that defines the volumes and other objects within a cluster.
    • Block drives store data blocks for volumes.
Element Software architectural diagram
You can manage, monitor, and update the system using the Element web UI and other compatible tools:
Common URLs
These are the common URLs you use with a SolidFire all-flash storage system:
URL Description
https://[storage cluster MVIP address]
Access the NetApp Element software UI.
https://activeiq.solidfire.com
Monitor data and receive alerts to any performance bottlenecks or potential system issues.
https://[management node IP address]
Access NetApp Hybrid Cloud Control to upgrade your storage installation and update management services.
https://[IP address]:442
From the per-node UI, access network and cluster settings and utilize system tests and utilities. Learn more.
https://[management node IP address]/mnode
Use management services REST API and other functionality from the management node. Learn more.
https://[management node IP address]:9443
Register the vCenter Plug-in package in the vSphere Web Client. Learn more.
