Prepare Element cluster for FIPS drives feature
Security is becoming increasingly critical for the deployment of solutions in many customer environments. Federal Information Processing Standards (FIPS) are standards for computer security and interoperability. FIPS 140-2 certified encryption for data at rest is a component of the overall security solution.
To prepare for enabling the FIPS drives feature, you should avoid mixing nodes where some are FIPS drives capable and some are not.
A cluster is considered FIPS drives compliant based on the following conditions:
All drives are certified as FIPS drives.
All nodes are FIPS drives nodes.
Encryption at Rest (EAR) is enabled.
The FIPS drives feature is enabled. All drives and nodes must be FIPS capable and Encryption at Rest must be enabled in order to enable the FIPS drive feature.
