Enable SnapMirror on the Element cluster
You must enable SnapMirror on the Element cluster before you can create a replication relationship. You can only perform this task in the Element software web UI or using the API method.
The Element cluster must be running NetApp Element software version 10.1 or later.
SnapMirror can only be enabled for Element clusters used with NetApp ONTAP volumes.
The Element system comes with SnapMirror disabled by default. SnapMirror is not automatically enabled as part of a new installation or upgrade.
Once enabled, SnapMirror cannot be disabled. You can only disable the SnapMirror feature and restore the default settings by returning the cluster to the factory image. |
Click Clusters > Settings.
Find the cluster-specific settings for SnapMirror.
Click Enable SnapMirror.
