Active IQ Unified Manager
9.7
Add Group dialog box
The Add Group dialog box enables you to create groups to include clusters, volumes, and SVMs based on the group rules.
You must have the Application Administrator or Storage Administrator role.
  • Name
    Specifies the name of the group. You must enter a unique name for the group.
  • Description
    Specifies a meaningful description of the group.
Command buttons
The command buttons enable you to add or cancel the creation of a new group.
  • Add
    Creates the new group.
  • Cancel
    Closes the Add Group dialog box without saving your changes.
