Active IQ Unified Manager
9.7
Aggregate capacity fields
The following fields are available in the Aggregate Capacity and Utilization report and can be used in custom views and in reports.
  • Aggregate
    The aggregate name.
  • Daily Growth Rate %
    The growth rate that occurs every 24 hours in the aggregate.
  • Days To Full
    The estimated number of days remaining before the aggregate reaches full capacity.
  • Overcommitted Capacity %
    The aggregate overcommitment as a percentage.
  • Available Data %
    The available data capacity as a percentage.
  • Available Data Capacity
    The available data capacity.
  • Used Data %
    The used data capacity as a percentage.
  • Used Data Capacity
    The used data capacity.
  • Total Data Capacity
    The total data capacity (used plus available).
  • Logical Space Used
    The real size of the data that is being stored on the aggregate without applying the savings from using ONTAP storage efficiency technologies.
  • Snapshot Reserve Available %
    The amount of space available for Snapshot copies as a percentage.
  • Snapshot Reserve Available Capacity
    The amount of space available for Snapshot copies.
  • Snapshot Reserve Used %
    The amount of space used by Snapshot copies from the snapshot reserve as a percentage.
  • Snapshot Reserve Used Capacity
    The amount of space used by snapshot copies from the snapshot reserve.
  • Snapshot Reserve Total Capacity
    The total snapshot reserve capacity of the aggregate.
  • Cloud Tier Space Used
    The amount of data capacity that is currently being used in the cloud tier.
  • Cloud Tier
    The name of the cloud tier object store when it was created by ONTAP.
  • State
    The current state of the aggregate.
  • Type
    The aggregate type:
    • HDD
    • Hybrid
      Combines HDDs and SSDs, but Flash Pool has not been enabled.
    • Hybrid (Flash Pool)
      Combines HDDs and SSDs, and Flash Pool has been enabled.
    • SSD
    • SSD (FabricPool)
      Combines SSDs and a cloud tier
    • VMDisk (SDS)
      Virtual disks within a virtual machine
    • VMDisk (FabricPool)
      Combines virtual disks and a cloud tier
    • LUN (FlexArray)
  • RAID Type
    The RAID configuration type.
  • SnapLock Type
    The aggregate SnapLock Type. The possible values are Compliance, Enterprise, Non-SnapLock.
  • HA Pair
    The HA pair value obtained by forming two nodes.
  • Node
    The name of the node that contains the aggregate.
  • Cluster
    The cluster name. You can click the cluster name to navigate to that cluster's capacity details page.
  • Cluster FQDN
    The fully qualified domain name (FQDN) of the cluster.
