Active IQ Unified Manager
9.7
Users page
The Users page displays a list of your users and groups, and provides information such as the name, type of user, and email address. You can also use this page to perform tasks such as adding, editing, deleting, and testing users.
Command buttons
The command buttons enable you to perform the following tasks for selected users:
  • Add
    Displays the Add User dialog box, which enables you to add a local user, a remote user, a remote group, or a database user.
    You can add remote users or groups only if your authentication server is enabled and configured.
  • Edit
    Displays the Edit User dialog box, which enables you to edit the settings for the selected user.
  • Delete
    Deletes the selected users from the management server database.
  • Test
    Enables you to validate whether a remote user or group is present in the authentication server.
    You can perform this task only if your authentication server is enabled and configured.
List view
The List view displays, in tabular format, information about the users that are created. You can use the column filters to customize the data that is displayed.
  • Name
    Displays the name of the user or group.
  • Type
    Displays the type of user: Local User, Remote User, Remote Group, Database User, or Maintenance User.
  • Email
    Displays the email address of the user.
  • Role
    Displays the type of role that is assigned to the user: Operator, Storage Administrator, Application Administrator, Integration Schema, or Report Schema.
