Assets used in queries
Download PDF of this page
Queries enable you to monitor and troubleshoot your network by searching the assets and metrics in your environment at a granular level based on user-selected criteria (for example, annotations).
Note that annotation rules, which automatically assign annotations to assets, require a query.
You can query the physical or virtual inventory assets (and their associated metrics) in your environment, or the metrics provided with integration such as Kubernetes or ONTAP Advanced Data.
Inventory Assets
The following asset types can be used in queries, dashboard widgets, and custom asset landing pages. The fields and counters available for filters, expressions, and display will vary among asset types. Not all assets can be used in all widget types.
Application
Datastore
Disk
Fabric
Generic Device
Host
Internal Volume
iSCSI Session
iSCSI Network Portal
Path
Port
Qtree
Quota
Share
Storage
Storage Node
Storage Pool
Storage Virtual Machine (SVM)
Switch
Tape
VMDK
Virtual Machine
Volume
Zone
Zone Member
Integration Metrics
In addition to querying for inventory assets and their associated performance metrics, you can query for integration data metrics as well, such as those generated by Kubernetes or Docker, or provided with ONTAP Advanced Metrics.
