Webhook Example for Slack
Webhooks allow users to send alert notifications to various applications using a customized webhook channel. This page provides an example for setting up webhooks for Slack.
This page refers to third-party instructions, which could be subject to change. Refer to the Slack documentation for the most up-to-date information. |
Slack Example:
Go to https://api.slack.com/apps and Create a new App. Give it a meaningful name and select the Slack Workspace.
Go to Incoming Webhooks, click on Activate Incoming Webhooks, Request to Add New Webhook, and select the Channel on which to Post.
Copy the Webhook URL. You will need to paste this into the Data Infrastructure Insights webhook configuration.
Create Data Infrastructure Insights Webhook:
In Data Infrastructure Insights, navigate to Admin > Notifications and select the Webhooks tab. Click +Webhook to create a new webhook.
Give the webhook a meaningful Name, such as "Slack Webhook".
In the Template Type drop-down, select Slack.
Paste the URL from above into the URL field.
Notifications via Webhook
To notify on events via webhook, in Data Infrastructure Insights navigate to Alerts > Monitors and click +Monitor to create a new monitor.
Select a metric and define the monitor's conditions.
Under _Set up team notification(s), choose the Webhook Delivery Method.
Choose the "Slack" webhook for the desired events (Critical, Warning, Resolved)
More information:
To modify message format and layout, see https://api.slack.com/messaging/composing
Error handling: https://api.slack.com/messaging/webhooks#handling_errors
