在Cisco 9334C-966共享交换机上启用SSH
贡献者
如果要使用以太网交换机运行状况监控器(CSHM)和日志收集功能、则必须生成SSH密钥、然后在集群交换机上启用SSH。
步骤
验证SSH是否已禁用:
show ip ssh
显示示例
(switch)# show ip ssh SSH Configuration Administrative Mode: .......................... Disabled SSH Port: ..................................... 22 Protocol Level: ............................... Version 2 SSH Sessions Currently Active: ................ 0 Max SSH Sessions Allowed: ..................... 5 SSH Timeout (mins): ........................... 5 Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521) Key Generation In Progress: ................... None SSH Public Key Authentication Mode: ........... Disabled SCP server Administrative Mode: ............... Disabled
生成 SSH 密钥:
crypto key generate
显示示例
(switch)# config (switch) (Config)# crypto key generate rsa Do you want to overwrite the existing RSA keys? (y/n): y (switch) (Config)# crypto key generate dsa Do you want to overwrite the existing DSA keys? (y/n): y (switch) (Config)# crypto key generate ecdsa 521 Do you want to overwrite the existing ECDSA keys? (y/n): y (switch) (Config)# aaa authorization commands "noCmdAuthList" none (switch) (Config)# exit (switch)# ip ssh server enable (switch)# ip scp server enable (switch)# ip ssh pubkey-auth (switch)# write mem This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully. Configuration Saved!
重新启动交换机:
re负载
验证是否已启用 SSH :
show ip ssh
显示示例
(switch)# show ip ssh SSH Configuration Administrative Mode: .......................... Enabled SSH Port: ..................................... 22 Protocol Level: ............................... Version 2 SSH Sessions Currently Active: ................ 0 Max SSH Sessions Allowed: ..................... 5 SSH Timeout (mins): ........................... 5 Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521) Key Generation In Progress: ................... None SSH Public Key Authentication Mode: ........... Enabled SCP server Administrative Mode: ............... Enabled
下一步是什么?
"配置交换机运行状况监控"(英文)
