Enable SSH on Cisco 9336C-FX2 shared switches
If you are using the Ethernet Switch Health Monitor (CSHM) and log collection features, you must generate the SSH keys and then enable SSH on the cluster switches.
Steps
Verify that SSH is disabled:
show ip ssh
Show example
(switch)# show ip ssh SSH Configuration Administrative Mode: .......................... Disabled SSH Port: ..................................... 22 Protocol Level: ............................... Version 2 SSH Sessions Currently Active: ................ 0 Max SSH Sessions Allowed: ..................... 5 SSH Timeout (mins): ........................... 5 Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521) Key Generation In Progress: ................... None SSH Public Key Authentication Mode: ........... Disabled SCP server Administrative Mode: ............... Disabled
Generate the SSH keys:
crypto key generate
Show example
(switch)# config (switch) (Config)# crypto key generate rsa Do you want to overwrite the existing RSA keys? (y/n): y (switch) (Config)# crypto key generate dsa Do you want to overwrite the existing DSA keys? (y/n): y (switch) (Config)# crypto key generate ecdsa 521 Do you want to overwrite the existing ECDSA keys? (y/n): y (switch) (Config)# aaa authorization commands "noCmdAuthList" none (switch) (Config)# exit (switch)# ip ssh server enable (switch)# ip scp server enable (switch)# ip ssh pubkey-auth (switch)# write mem This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully. Configuration Saved!
Reboot the switch:
reload
Verify that SSH is enabled:
show ip ssh
Show example
(switch)# show ip ssh SSH Configuration Administrative Mode: .......................... Enabled SSH Port: ..................................... 22 Protocol Level: ............................... Version 2 SSH Sessions Currently Active: ................ 0 Max SSH Sessions Allowed: ..................... 5 SSH Timeout (mins): ........................... 5 Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521) Key Generation In Progress: ................... None SSH Public Key Authentication Mode: ........... Enabled SCP server Administrative Mode: ............... Enabled
What's next?
