配置 Cisco Nexus 92300YC 集群交换机
使用初始设置命令配置 Cisco Nexus 92300YC 集群交换机,使其为集群操作做好准备。
步骤
将串口连接到主机或串口。
将管理端口(在交换机的非端口侧)连接到 SFTP 服务器所在的同一网络。
在控制台上,设置主机端串行设置:
9600 波特
8 位数据
1 停止位
奇偶性:无
流量控制:无
当第一次引导或在擦除运行配置后重新引导时,Nexus 92300YC 交换机会在引导周期中循环。键入 yes 以中止"开启自动配置",从而中断此循环。
此时将显示系统管理员帐户设置。
显示示例
$ VDC-1 %$ %POAP-2-POAP_INFO: - Abort Power On Auto Provisioning [yes - continue with normal setup, skip - bypass password and basic configuration, no - continue with Power On Auto Provisioning] (yes/skip/no)[no]: y Disabling POAP.......Disabling POAP 2019 Apr 10 00:36:17 switch %$ VDC-1 %$ poap: Rolling back, please wait... (This may take 5-15 minutes) ---- System Admin Account Setup ---- Do you want to enforce secure password standard (yes/no) [y]: -
键入 y 以强制执行安全密码标准:
Do you want to enforce secure password standard (yes/no) [y]: y
输入并确认用户 admin 的密码:
Enter the password for "admin": Confirm the password for "admin":
键入 yes 以进入"基本系统配置"对话框。
显示示例
This setup utility will guide you through the basic configuration of the system. Setup configures only enough connectivity for management of the system. Please register Cisco Nexus9000 Family devices promptly with your supplier. Failure to register may affect response times for initial service calls. Nexus9000 devices must be registered to receive entitled support services. Press Enter at anytime to skip a dialog. Use ctrl-c at anytime to skip the remaining dialogs. Would you like to enter the basic configuration dialog (yes/no):
创建另一个登录帐户:
Create another login account (yes/no) [n]:
配置只读和读写 SNMP 社区字符串:
Configure read-only SNMP community string (yes/no) [n]: Configure read-write SNMP community string (yes/no) [n]:
配置集群交换机名称:
Enter the switch name : cs2
配置带外管理界面:
Continue with Out-of-band (mgmt0) management configuration? (yes/no) [y]: y Mgmt0 IPv4 address : 172.22.133.216 Mgmt0 IPv4 netmask : 255.255.224.0 Configure the default gateway? (yes/no) [y]: y IPv4 address of the default gateway : 172.22.128.1
配置高级 IP 选项:
Configure advanced IP options? (yes/no) [n]: n
配置 Telnet 服务:
Enable the telnet service? (yes/no) [n]: n
配置 SSH 服务和 SSH 密钥:
Enable the ssh service? (yes/no) [y]: y Type of ssh key you would like to generate (dsa/rsa) [rsa]: rsa Number of rsa key bits <1024-2048> [1024]: 2048 -
配置其他设置:
Configure the ntp server? (yes/no) [n]: n Configure default interface layer (L3/L2) [L2]: L2 Configure default switchport interface state (shut/noshut) [noshut]: noshut Configure CoPP system profile (strict/moderate/lenient/dense) [strict]: strict
确认交换机信息并保存配置:
Would you like to edit the configuration? (yes/no) [n]: n Use this configuration and save it? (yes/no) [y]: y [] 100% Copy complete, now saving to disk (please wait)... Copy complete.
下一步是什么?
配置好交换机后,您就可以"准备安装NX-OS软件和RCF"了。
