配置SNMPv3
按照此操作步骤配置SNMPv3、此SNMPv3支持以太网交换机运行状况监控(CSHM)。
以下命令用于在NVIDIA SN2100交换机上配置SNMPv3用户名:
对于*无身份验证*:
net add snmp-server username SNMPv3用户 auth-none
对于* MD5/SHA身份验证*:
net add snmp-server username SNMPv3用户[auth-md5_auth-sha]AUTH-password
对于采用AES/DES加密的* MD5/SHA身份验证*:
net add snmp-server username SNMPv3用户[auth-md5_auth-sha]AUTH-password[encrypt-AES_encrypt-des]PRIV-password
以下命令会在ONTAP 端配置SNMPv3用户名:cluster1:::*> security login create -user-or-group-name SNMPv3用户-application snmp -authentication-method USM -remote-switch-ipaddress address
以下命令将使用CSHM建立SNMPv3用户名:
cluster1::*> system switch ethernet modify -device DEVICE -snmp-version SNMPv3 -community-or-username SNMPv3_USER
在交换机上设置SNMPv3用户以使用身份验证和加密:
net show snmp status
显示示例
cumulus@sw1:~$ net show snmp status Simple Network Management Protocol (SNMP) Daemon. --------------------------------- ---------------- Current Status active (running) Reload Status enabled Listening IP Addresses all vrf mgmt Main snmpd PID 4318 Version 1 and 2c Community String Configured Version 3 Usernames Not Configured --------------------------------- ---------------- cumulus@sw1:~$ cumulus@sw1:~$ net add snmp-server username SNMPv3User auth-md5 <password> encrypt-aes <password> cumulus@sw1:~$ net commit --- /etc/snmp/snmpd.conf 2020-08-02 21:09:34.686949282 +0000 +++ /run/nclu/snmp/snmpd.conf 2020-08-11 00:13:51.826126655 +0000 @@ -1,26 +1,28 @@ # Auto-generated config file: do not edit. # agentaddress udp:@mgmt:161 agentxperms 777 777 snmp snmp agentxsocket /var/agentx/master createuser _snmptrapusernameX +createuser SNMPv3User MD5 <password> AES <password> ifmib_max_num_ifaces 500 iquerysecname _snmptrapusernameX master agentx monitor -r 60 -o laNames -o laErrMessage "laTable" laErrorFlag != 0 pass -p 10 1.3.6.1.2.1.1.1 /usr/share/snmp/sysDescr_pass.py pass_persist 1.2.840.10006.300.43 /usr/share/snmp/ieee8023_lag_pp.py pass_persist 1.3.6.1.2.1.17 /usr/share/snmp/bridge_pp.py pass_persist 1.3.6.1.2.1.31.1.1.1.18 /usr/share/snmp/snmpifAlias_pp.py pass_persist 1.3.6.1.2.1.47 /usr/share/snmp/entity_pp.py pass_persist 1.3.6.1.2.1.99 /usr/share/snmp/entity_sensor_pp.py pass_persist 1.3.6.1.4.1.40310.1 /usr/share/snmp/resq_pp.py pass_persist 1.3.6.1.4.1.40310.2 /usr/share/snmp/cl_drop_cntrs_pp.py pass_persist 1.3.6.1.4.1.40310.3 /usr/share/snmp/cl_poe_pp.py pass_persist 1.3.6.1.4.1.40310.4 /usr/share/snmp/bgpun_pp.py pass_persist 1.3.6.1.4.1.40310.5 /usr/share/snmp/cumulus-status.py pass_persist 1.3.6.1.4.1.40310.6 /usr/share/snmp/cumulus-sensor.py pass_persist 1.3.6.1.4.1.40310.7 /usr/share/snmp/vrf_bgpun_pp.py +rocommunity cshm1! default rouser _snmptrapusernameX +rouser SNMPv3User priv sysobjectid 1.3.6.1.4.1.40310 sysservices 72 -rocommunity cshm1! default net add/del commands since the last "net commit" ================================================ User Timestamp Command ---------- -------------------------- ------------------------------------------------------------------------- SNMPv3User 2020-08-11 00:13:51.826987 net add snmp-server username SNMPv3User auth-md5 <password> encrypt-aes <password> cumulus@sw1:~$ cumulus@sw1:~$ net show snmp status Simple Network Management Protocol (SNMP) Daemon. --------------------------------- ---------------- Current Status active (running) Reload Status enabled Listening IP Addresses all vrf mgmt Main snmpd PID 24253 Version 1 and 2c Community String Configured Version 3 Usernames Configured <---- Configured here --------------------------------- ---------------- cumulus@sw1:~$
在ONTAP 端设置SNMPv3用户:
security login create -user-or-group-name SNMPv3User -application snmp -authentication-method usm -remote-switch-ipaddress 10.231.80.212
显示示例
cluster1::*> security login create -user-or-group-name SNMPv3User -application snmp -authentication-method usm -remote-switch-ipaddress 10.231.80.212 Enter the authoritative entity's EngineID [remote EngineID]: Which authentication protocol do you want to choose (none, md5, sha, sha2-256) [none]: md5 Enter the authentication protocol password (minimum 8 characters long): Enter the authentication protocol password again: Which privacy protocol do you want to choose (none, des, aes128) [none]: aes128 Enter privacy protocol password (minimum 8 characters long): Enter privacy protocol password again:
将CSHM配置为使用新SNMPv3用户进行监控:
system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance
显示示例
cluster1::*> system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance Device Name: sw1 (b8:59:9f:09:7c:22) IP Address: 10.231.80.212 SNMP Version: SNMPv2c Is Discovered: true DEPRECATED-Community String or SNMPv3 Username: - Community String or SNMPv3 Username: cshm1! Model Number: MSN2100-CB2FC Switch Network: cluster-network Software Version: Cumulus Linux version 4.4.3 running on Mellanox Technologies Ltd. MSN2100 Reason For Not Monitoring: None Source Of Switch Version: LLDP Is Monitored ?: true Serial Number of the Device: MT2110X06399 <---- serial number to check RCF Version: MSN2100-RCF-v1.9X6-Cluster-LLDP Aug-18-2022 cluster1::*> cluster1::*> system switch ethernet modify -device "sw1 (b8:59:9f:09:7c:22)" -snmp-version SNMPv3 -community-or-username SNMPv3User
确认在CSHM轮询周期完成后、使用新创建的SNMPv3用户查询的序列号与上一步中详述的序列号相同。
system switch ethernet polling-interval show
显示示例
cluster1::*> system switch ethernet polling-interval show Polling Interval (in minutes): 5 cluster1::*> system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance Device Name: sw1 (b8:59:9f:09:7c:22) IP Address: 10.231.80.212 SNMP Version: SNMPv3 Is Discovered: true DEPRECATED-Community String or SNMPv3 Username: - Community String or SNMPv3 Username: SNMPv3User Model Number: MSN2100-CB2FC Switch Network: cluster-network Software Version: Cumulus Linux version 4.4.3 running on Mellanox Technologies Ltd. MSN2100 Reason For Not Monitoring: None Source Of Switch Version: LLDP Is Monitored ?: true Serial Number of the Device: MT2110X06399 <---- serial number to check RCF Version: MSN2100-RCF-v1.9X6-Cluster-LLDP Aug-18-2022
