Device Resolution rules
You create device resolution rules to identify hosts, storage, and tapes that are not automatically identified currently by Cloud Insights. The rules that you create identify devices currently in your environment and also identify similar devices as they are added to your environment.
Creating Device Resolution Rules
When you create rules you start by identifying the source of information that the rule runs against, the method used to extract information, and whether DNS lookup is applied to the results of the rule.
Source that is used to identify the device |
* SRM aliases for hosts |
Method that is used to extract the device name from the source |
* As is (extract a name from an SRM) |
DNS lookup |
Specifies if you use DNS to verify the host name |
You create rules in the Auto Resolution Rules tab. The following steps describe the rule creation process.
Click Manage > Device Resolution
In the Auto resolution rules tab, click + Host Rule or + Tape Rule.
The Resolution Rule screen is displayed.
Click the View matching criteria link for help with and examples for creating regular expressions. -
In the Type list select the device you want to identify.
You can select Host or Tape.
In the Source list, select the source you want to use to identify the host.
Depending on the source you chose, Cloud Insights displays the following response:
Zones lists the zones and WWN that need to be identified by Cloud Insights.
SRM lists the unidentified aliases that need to be identified by Cloud Insights
Storage alias lists storage aliases and WWN that need to be identified by Cloud Insights
Switch alias lists the switch aliases that need to be identified by Cloud Insights
In the Method list select the method you want to employ to identify the host.
Source
Method
SRM
As is, Delimiters, Regular expressions
Storage alias
Switch alias
Zones
Rules using Delimiters require the delimiters and the minimum length of the host name.
The minimum length of the host name is number of characters that Cloud Insights should use to identify a host. Cloud Insights performs DNS lookups only for host names that are this long or longer.For rules using Delimiters, the input string is tokenized by the delimiter and a list of host name candidates is created by making several combinations of the adjacent token. The list is then sorted, largest to smallest. For example, for an input sring of vipsnq03_hba3_emc3_12ep0 the list would result in the following:
vipsnq03_hba3_emc3
hba3 emc3_12ep0
vipsnq03_hba3
emc3_12ep0
hba3_emc3
vipsnq03
12ep0
emc3
hba3
Rules using Regular expressions require a regular expression, the format, and cases sensitivity selection.
Click Run AR to run all rules, or click the down-arrow in the button to run the rule you created (and any other rules that have been created since the last full run of AR).
The results of the rule run are displayed in the FC identify tab.
Starting an automatic device resolution update
A device resolution update commits manual changes that have been added since the last full automatic device resolution run. Running an update can be used to commit and run only the new manual entries made to the device resolution configuration. No full device resolution run is performed.
Log into the Cloud Insights web UI.
In the Device Resolution screen, click the down-arrow in the Run AR button.
Click Update to start the update.
Rule-assisted manual identification
This feature is used for special cases where you want to run a specific rule or a list of rules (with or without a one-time reordering) to resolve unknown hosts, storage, and tape devices.
You have a number of devices that have not been identified and you also have multiple rules that successfully identified other devices.
If your source only contains part of a host or device name, use a regular expression rule and format it to add the missing text. |
Click the Fibre Channel Identify tab.
The system displays the devices along with their resolution status.
Select multiple unidentified devices.
Click Bulk Actions and select Set host resolution or Set tape resolution.
The system displays the Identify screen which contains a list of all of the rules that successfully identified devices.
Change the order of the rules to an order that meets your needs.
The order of the rules are changed in the Identify screen, but are not changed globally.
Select the method that that meets your needs.
Cloud Insights executes the host resolution process in the order in which the methods appear, beginning with those at the top.
When rules that apply are encountered, rule names are shown in the rules column and identified as manual.
