2. Configure Data Switches
Mellanox SN2010 switches provide 25Gbps connectivity for the data plane of the compute and storage nodes. To configure the switches to provide data connectivity to the infrastructure, complete the following steps:
Create MLAG cluster to provide fault tolerance
Run the following commands on each Mellanox SN210 switch for general configuration:
Enter configuration mode.
Switch-01 enable Switch-01 configure terminal
Enable the LACP required for the Inter-Peer Link (IPL).
Switch-01 (config) # lacp
Enable the Link Layer Discovery Protocol (LLDP).
Switch-01 (config) # lldp
Enable IP routing.
Switch-01 (config) # ip routing
Enable the MLAG protocol.
Switch-01 (config) # protocol mlag
Enable global QoS.
Switch-01 (config) # dcb priority-flow-control enable force
For MLAG to function, the switches must be made peers to each other through an IPL. This should consist of two or more physical links for redundancy. The MTU for the IPL is set for jumbo frames (9216), and all VLANs are enabled by default. Run the following commands on each switch in the domain:
Create port channel 10 for the IPL.
Switch-01 (config) # interface port-channel 10 Switch-01 (config interface port-channel 10) # description IPL Switch-01 (config interface port-channel 10) # exit
Add interfaces ETH 1/20 and 1/22 to the port channel.
Switch-01 (config) # interface ethernet 1/20 channel-group 10 mode active Switch-01 (config) # interface ethernet 1/20 description ISL-SWB_01 Switch-01 (config) # interface ethernet 1/22 channel-group 10 mode active Switch-01 (config) # interface ethernet 1/22 description ISL-SWB_02
Create a VLAN outside of the standard range dedicated to IPL traffic.
Switch-01 (config) # vlan 4000 Switch-01 (config vlan 4000) # name IPL VLAN Switch-01 (config vlan 4000) # exit
Define the port channel as the IPL.
Switch-01 (config) # interface port-channel 10 ipl 1 Switch-01 (config) # interface port-channel 10 dcb priority-flow-control mode on force
Set an IP for each IPL member (non-routable; it is not advertised outside of the switch).
Switch-01 (config) # interface vlan 4000 Switch-01 (config vlan 4000) # ip address 10.0.0.1 255.255.255.0 Switch-01 (config vlan 4000) # ipl 1 peer-address 10.0.0.2 Switch-01 (config vlan 4000) # exit
Create a unique MLAG domain name for the two switches and assign an MLAG virtual IP (VIP). This IP is used for keep-alive heartbeat messages between the two switches. Run these commands on each switch in the domain:
Create the MLAG domain and set the IP address and subnet.
Switch-01 (config) # mlag-vip MLAG-VIP-DOM ip a.b.c.d /24 force
Create a virtual MAC address for the system MLAG.
Switch-01 (config) # mlag system-mac AA:BB:CC:DD:EE:FF
Configure the MLAG domain so that it is active globally.
Switch-01 (config) # no mlag shutdown
The IP used for the MLAG VIP must be in the same subnet as the switch management network (mgmt0). |
The MAC address used can be any unicast MAC address and must be set to the same value on both switches in the MLAG domain. |
Configure ports to connect to storage and compute hosts
Create each of the VLANs needed to support the services for NetApp HCI. Run these commands on each switch in the domain:
Create VLANs.
Switch-01 (config) # vlan 1172 Switch-01 (config vlan 1172) exit Switch-01 (config) # vlan 3480-3482 Switch-01 (config vlan 3480-3482) exit
Create names for each VLAN for easier accounting.
Switch-01 (config) # vlan 1172 name “VM_Network” Switch-01 (config) # vlan 3480 name “MGMT_Network” Switch-01 (config) # vlan 3481 name “Storage_Network” Switch-01 (config) # vlan 3482 name “vMotion_Network” +
Create hybrid VLAN ports on ports ETH1/9-10 so that you can tag the appropriate VLANs for the NetApp HCI compute nodes.
Select the ports you want to work with.
Switch-01 (config) # interface ethernet 1/9-1/10
Set the MTU for each port.
Switch-01 (config interface ethernet 1/9-1/10) # mtu 9216 force
Modify spanning-tree settings for each port.
Switch-01 (config interface ethernet 1/9-1/10) # spanning-tree bpdufilter enable Switch-01 (config interface ethernet 1/9-1/10) # spanning-tree port type edge Switch-01 (config interface ethernet 1/9-1/10) # spanning-tree bpduguard enable
Set the switchport mode to hybrid.
Switch-01 (config interface ethernet 1/9-1/10 ) # switchport mode hybrid Switch-01 (config interface ethernet 1/9-1/10 ) # exit
Create descriptions for each port being modified.
Switch-01 (config) # interface ethernet 1/9 description HCI-CMP-01 PortD Switch-01 (config) # interface ethernet 1/10 description HCI-CMP-02 PortD
Tag the appropriate VLANs for the NetApp HCI environment.
Switch-01 (config) # interface ethernet 1/9 switchport hybrid allowed-vlan add 1172 Switch-01 (config) # interface ethernet 1/9 switchport hybrid allowed-vlan add 3480-3482 Switch-01 (config) # interface ethernet 1/10 switchport hybrid allowed-vlan add 1172 Switch-01 (config) # interface ethernet 1/10 switchport hybrid allowed-vlan add 3480-3482
Create MLAG interfaces and hybrid VLAN ports on ports ETH1/5-8 so that you can distribute connectivity between the switches and tag the appropriate VLANs for the NetApp HCI storage nodes.
Select the ports that you want to work with.
Switch-01 (config) # interface ethernet 1/5-1/8
Switch-01 (config interface ethernet 1/5-1/8) # mtu 9216 force
Modify spanning tree settings for each port.
Switch-01 (config interface ethernet 1/5-1/8) # spanning-tree bpdufilter enable Switch-01 (config interface ethernet 1/5-1/8) # spanning-tree port type edge Switch-01 (config interface ethernet 1/5-1/8) # spanning-tree bpduguard enable
Switch-01 (config interface ethernet 1/5-1/8 ) # switchport mode hybrid Switch-01 (config interface ethernet 1/5-1/8 ) # exit
Switch-01 (config) # interface ethernet 1/5 description HCI-STG-01 PortD Switch-01 (config) # interface ethernet 1/6 description HCI-STG-02 PortD Switch-01 (config) # interface ethernet 1/7 description HCI-STG-03 PortD Switch-01 (config) # interface ethernet 1/8 description HCI-STG-04 PortD
Create and configure the MLAG port channels.
Switch-01 (config) # interface mlag-port-channel 115-118 Switch-01 (config interface mlag-port-channel 115-118) # exit Switch-01 (config) # interface mlag-port-channel 115-118 no shutdown Switch-01 (config) # interface mlag-port-channel 115-118 mtu 9216 force Switch-01 (config) # interface mlag-port-channel 115-118 lacp-individual enable force Switch-01 (config) # interface ethernet 1/5-1/8 lacp port-priority 10 Switch-01 (config) # interface ethernet 1/5-1/8 lacp rate fast Switch-01 (config) # interface ethernet 1/5 mlag-channel-group 115 mode active Switch-01 (config) # interface ethernet 1/6 mlag-channel-group 116 mode active Switch-01 (config) # interface ethernet 1/7 mlag-channel-group 117 mode active Switch-01 (config) # interface ethernet 1/8 mlag-channel-group 118 mode active
Tag the appropriate VLANs for the storage environment.
Switch-01 (config) # interface mlag-port-channel 115-118 switchport mode hybrid Switch-01 (config) # interface mlag-port-channel 115 switchport hybrid allowed-vlan add 1172 Switch-01 (config) # interface mlag-port-channel 116 switchport hybrid allowed-vlan add 1172 Switch-01 (config) # interface mlag-port-channel 117 switchport hybrid allowed-vlan add 1172 Switch-01 (config) # interface mlag-port-channel 118 switchport hybrid allowed-vlan add 1172 Switch-01 (config) # interface mlag-port-channel 115 switchport hybrid allowed-vlan add 3481 Switch-01 (config) # interface mlag-port-channel 116 switchport hybrid allowed-vlan add 3481 Switch-01 (config) # interface mlag-port-channel 117 switchport hybrid allowed-vlan add 3481 Switch-01 (config) # interface mlag-port-channel 118 switchport hybrid allowed-vlan add 3481
The configurations in this section must also be run on the second switch in the MLAG domain. NetApp recommends that the descriptions for each port are updated to reflect the device ports that are cabled and configured on the other switch. |
Create uplink ports for the switches
Create an MLAG interface to provide uplinks to both Mellanox SN2010 switches from the core network.
Switch-01 (config) # interface mlag port-channel 101 Switch-01 (config interface mlag port-channel) # description Uplink CORE-SWITCH port PORT Switch-01 (config interface mlag port-channel) # exit
Configure the MLAG members.
Switch-01 (config) # interface ethernet 1/18 description Uplink to CORE-SWITCH port PORT Switch-01 (config) # interface ethernet 1/18 speed 10000 force Switch-01 (config) # interface mlag-port-channel 101 mtu 9216 force Switch-01 (config) # interface ethernet 1/18 mlag-channel-group 101 mode active
Set the switchport mode to hybrid and allow all VLANs from the core uplink switches.
Switch-01 (config) # interface mlag-port-channel switchport mode hybrid Switch-01 (config) # interface mlag-port-channel switchport hybrid allowed-vlan all
Verify that the MLAG interface is up.
Switch-01 (config) # interface mlag-port-channel 101 no shutdown Switch-01 (config) # exit
