Configure NetApp H615c (Manual Deployment)
In this solution, the NetApp H615c compute nodes are configured as Kubernetes worker nodes. The Inferencing workload is hosted on these nodes.
Deploying the compute nodes involves the following tasks:
Install Ubuntu 18.04.4 LTS.
Configure networking for data and management access.
Prepare the Ubuntu instances for Kubernetes deployment.
The following high-level steps are required to install the operating system on the H615c compute nodes:
Download Ubuntu 18.04.4 LTS from Ubuntu releases.
Using a browser, connect to the IPMI of the H615c node and launch Remote Control.
Map the Ubuntu ISO using the Virtual Media Wizard and start the installation.
Select one of the two physical interfaces as the
Primary network interfacewhen prompted.An IP from a DHCP source is allocated when available, or you can switch to a manual IP configuration later. The network configuration is modified to a bond-based setup after the OS has been installed.
Provide a hostname followed by a domain name.
Create a user and provide a password.
Partition the disks according to your requirements.
Under Software Selection, select
OpenSSH serverand click Continue. -
Reboot the node.
Configure Networking for Data and Management Access
The two physical network interfaces of the Kubernetes worker nodes are set up as a bond and VLAN interfaces for management and application, and NFS data traffic is created on top of it.
The inferencing applications and associated containers use the application network for connectivity. |
Connect to the console of the Ubuntu instance as a user with root privileges and launch a terminal session.
Navigate to
/etc/netplanand open the01-netcfg.yamlfile. -
Update the netplan file based on the network details for the management, application, and NFS traffic in your environment.
The following template of the netplan file was used in this solution:
# This file describes the network interfaces available on your system # For more information, see netplan(5). network: version: 2 renderer: networkd ethernets: enp59s0f0: #Physical Interface 1 match: macaddress: <<mac_address Physical Interface 1>> set-name: enp59s0f0 mtu: 9000 enp59s0f1: # Physical Interface 2 match: macaddress: <<mac_address Physical Interface 2>> set-name: enp59s0f1 mtu: 9000 bonds: bond0: mtu: 9000 dhcp4: false dhcp6: false interfaces: [ enp59s0f0, enp59s0f1 ] parameters: mode: 802.3ad mii-monitor-interval: 100 vlans: vlan.3488: #Management VLAN id: 3488 link: bond0 dhcp4: false addresses: [ipv4_address/subnet] routes: - to: 0.0.0.0/0 via: 172.21.232.111 metric: 100 table: 3488 - to: x.x.x.x/x # Additional routes if any via: y.y.y.y metric: <<metric>> table: <<table #>> routing-policy: - from: 0.0.0.0/0 priority: 32768#Higher Priority than table 3487 table: 3488 nameservers: addresses: [nameserver_ip] search: [ search_domain ] mtu: 1500 vlan.3487: id: 3487 link: bond0 dhcp4: false addresses: [ipv4_address/subnet] routes: - to: 0.0.0.0/0 via: 172.21.231.111 metric: 101 table: 3487 - to: x.x.x.x/x via: y.y.y.y metric: <<metric>> table: <<table #>> routing-policy: - from: 0.0.0.0/0 priority: 32769#Lower Priority table: 3487 nameservers: addresses: [nameserver_ip] search: [ search_domain ] mtu: 1500 vlan.3491: id: 3491 link: bond0 dhcp4: false addresses: [ipv4_address/subnet] mtu: 9000 -
Confirm that the priorities for the routing policies are lower than the priorities for the main and default tables.
Apply the netplan.
sudo netplan -–debug apply
Make sure that there are no errors.
If Network Manager is running, stop and disable it.
systemctl stop NetworkManager systemctl disable NetworkManager
Add a host record for the server in DNS.
Open a VI editor to
/etc/iproute2/rt_tablesand add the two entries.# # reserved values # 255 local 254 main 253 default 0 unspec # # local # #1 inr.ruhep 101 3488 102 3487
Match the table number to what you used in the netplan.
Open a VI editor to
/etc/sysctl.confand set the value of the following parameters.net.ipv4.conf.default.rp_filter=0 net.ipv4.conf.all.rp_filter=0net.ipv4.ip_forward=1
Update the system.
sudo apt-get update && sudo apt-get upgrade
Reboot the system
Repeat steps 1 through 13 for the other Ubuntu instance.
