9. Download and Install NetApp Trident: NetApp HCI for Red Hat OpenShift on RHV
To download and install NetApp Trident, complete the following steps:
Make sure that the user that is logged in to the OCP cluster has sufficient privileges for installing Trident.
[user@rhel7 openshift-deploy]$ oc auth can-i '*' '*' --all-namespaces yes
Verify that you can download an image from the registry and access the MVIP of the NetApp Element cluster.
[user@rhel7 openshift-deploy]$ oc run -i --tty ping --image=busybox --restart=Never --rm -- ping 10.63.172.140 If you don't see a command prompt, try pressing enter. 64 bytes from 10.63.172.140: seq=1 ttl=63 time=0.312 ms 64 bytes from 10.63.172.140: seq=2 ttl=63 time=0.271 ms 64 bytes from 10.63.172.140: seq=3 ttl=63 time=0.254 ms 64 bytes from 10.63.172.140: seq=4 ttl=63 time=0.309 ms 64 bytes from 10.63.172.140: seq=5 ttl=63 time=0.319 ms 64 bytes from 10.63.172.140: seq=6 ttl=63 time=0.303 ms ^C --- 10.63.172.140 ping statistics --- 7 packets transmitted, 7 packets received, 0% packet loss round-trip min/avg/max = 0.254/0.387/0.946 ms pod "ping" deleted
Download the Trident installer bundle using the following commands and extract it to a directory.
[user@rhel7 ~]$ wget [user@rhel7 ~]$ tar -xf trident-installer-20.04.0.tar.gz [user@rhel7 ~]$ cd trident-installer
The Trident installer contains manifests for defining all the required resources. Using the appropriate manifests, create the TridentProvisioner custom resource definition.
[user@rhel7 trident-installer]$ oc create -f deploy/crds/trident.netapp.io_tridentprovisioners_crd_post1.16.yaml customresourcedefinition.apiextensions.k8s.io/tridentprovisioners.trident.netapp.io created
Create a Trident namespace, which is required for the Trident operator.
[user@rhel7 trident-installer]$ oc create namespace trident namespace/trident created
Create the resources required for the Trident operator deployment, such as a ServiceAccount for the operator, a ClusterRole and ClusterRoleBinding to the ServiceAccount, a dedicated PodSecurityPolicy, or the operator itself.
[user@rhel7 trident-installer]$ oc kustomize deploy/ > deploy/bundle.yaml [user@rhel7 trident-installer]$ oc create -f deploy/bundle.yaml serviceaccount/trident-operator created clusterrole.rbac.authorization.k8s.io/trident-operator created clusterrolebinding.rbac.authorization.k8s.io/trident-operator created deployment.apps/trident-operator created podsecuritypolicy.policy/tridentoperatorpods created
Verify that the Trident operator is deployed.
[user@rhel7 trident-installer]$ oc get deployment -n trident NAME READY UP-TO-DATE AVAILABLE AGE trident-operator 1/1 1 1 56s [user@rhel7 trident-installer]$ oc get pods -n trident NAME READY STATUS RESTARTS AGE trident-operator-564d7d66f-qrz7v 1/1 Running 0 71s
After the Trident operator is installed, install Trident using this operator. In this example, TridentProvisioner custom resource (CR) was created. The Trident installer comes with definitions for creating a TridentProvisioner CR. These can be modified based on the requirements.
[user@rhel7 trident-installer]$ oc create -f deploy/crds/tridentprovisioner_cr.yaml tridentprovisioner.trident.netapp.io/trident created
Approve the Trident serving CSR certificates by using
oc get csr -o name | xargs oc adm certificate approve.[user@rhel7 trident-installer]$ oc get csr -o name | xargs oc adm certificate approve certificatesigningrequest.certificates.k8s.io/csr-4b7zh approved certificatesigningrequest.certificates.k8s.io/csr-4hkwc approved certificatesigningrequest.certificates.k8s.io/csr-5bgh5 approved certificatesigningrequest.certificates.k8s.io/csr-5g4d6 approved certificatesigningrequest.certificates.k8s.io/csr-5j9hz approved certificatesigningrequest.certificates.k8s.io/csr-5m8qb approved certificatesigningrequest.certificates.k8s.io/csr-66hv2 approved certificatesigningrequest.certificates.k8s.io/csr-6rdgg approved certificatesigningrequest.certificates.k8s.io/csr-6t24f approved certificatesigningrequest.certificates.k8s.io/csr-76wgv approved certificatesigningrequest.certificates.k8s.io/csr-78qsq approved certificatesigningrequest.certificates.k8s.io/csr-7r58n approved certificatesigningrequest.certificates.k8s.io/csr-8ghmk approved certificatesigningrequest.certificates.k8s.io/csr-8sn5q approved
Verify that Trident 20.04 is installed by using the TridentProvisioner CR, and verify that the pods related to Trident are.
[user@rhel7 trident-installer]$ oc get tprov -n trident NAME AGE trident 9m49s [user@rhel7 trident-installer]$ oc describe tprov trident -n trident Name: trident Namespace: trident Labels: <none> Annotations: <none> API Version: trident.netapp.io/v1 Kind: TridentProvisioner Metadata: Creation Timestamp: 2020-05-26T18:49:19Z Generation: 1 Resource Version: 640347 Self Link: /apis/trident.netapp.io/v1/namespaces/trident/tridentprovisioners/trident UID: 52656806-0414-4ed8-b355-fc123fafbf4e Spec: Debug: true Status: Message: Trident installed Status: Installed Version: v20.04 Events: Type Reason Age From Message ---- ------ ---- ---- ------- Normal Installing 9m32s trident-operator.netapp.io Installing Trident Normal Installed 3m47s (x5 over 8m56s) trident-operator.netapp.io Trident installed [user@rhel7 trident-installer]$ oc get pods -n trident NAME READY STATUS RESTARTS AGE trident-csi-7f769c7875-s6fmt 5/5 Running 0 10m trident-csi-cp7wg 2/2 Running 0 10m trident-csi-hhx94 2/2 Running 0 10m trident-csi-l72bt 2/2 Running 0 10m trident-csi-xfl9d 2/2 Running 0 10m trident-csi-xrhqx 2/2 Running 0 10m trident-csi-zb7ws 2/2 Running 0 10m trident-operator-564d7d66f-qrz7v 1/1 Running 0 27m [user@rhel7 trident-installer]$ ./tridentctl -n trident version +----------------+----------------+ | SERVER VERSION | CLIENT VERSION | +----------------+----------------+ | 20.04.0 | 20.04.0 | +----------------+----------------+
Create a storage backend that will be used by Trident to provision volumes. The storage backend specifies the Element cluster in NetApp HCI. You also can specify sample bronze, silver, and gold types with corresponding QoS specs.
[user@rhel7 trident-installer]$ vi backend.json { "version": 1, "storageDriverName": "solidfire-san", "Endpoint": "https://admin: admin- password@10.63.172.140/json-rpc/8.0", "SVIP": "10.61.185.205:3260", "TenantName": "trident", "Types": [{"Type": "Bronze", "Qos": {"minIOPS": 1000, "maxIOPS": 2000, "burstIOPS": 4000}}, {"Type": "Silver", "Qos": {"minIOPS": 4000, "maxIOPS": 6000, "burstIOPS": 8000}}, {"Type": "Gold", "Qos": {"minIOPS": 6000, "maxIOPS": 8000, "burstIOPS": 10000}}] } [user@rhel7 trident-installer]$ ./tridentctl -n trident create backend -f backend.json +-------------------------+----------------+--------------------------------------+--------+---------+ | NAME | STORAGE DRIVER | UUID | STATE | VOLUMES | +-------------------------+----------------+--------------------------------------+--------+---------+ | solidfire_10.61.185.205 | solidfire-san | 40f48d99-5d2e-4f6c-89ab-8aee2be71255 | online | 0 | +-------------------------+----------------+--------------------------------------+--------+---------+Modify the
backend.jsonto accommodate the details or requirements of your environment for the following values:-
Endpoint corresponds to the credentials and the MVIP of the NetApp HCI Element cluster.
SVIP corresponds to the SVIP configured over the VM network in the section titled Create Storage Network VLAN.
Types corresponds to different QoS bands. New persistent volumes can be created with specific QoS settings by specifying the exact storage pool.
Create a StorageClass that specifies Trident as the provisioner and the storage backend as
solidfire-san.
[user@rhel7 trident-installer]$ vi storage-class-basic.yaml
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
annotations:
storageclass.kubernetes.io/is-default-class: "true"
parameters:
backendType: "solidfire-san"
provisioningType: "thin"
[user@rhel7 trident-installer]$ oc create -f storage-class-basic.yaml
storageclass.storage.k8s.io/basic created
In this example, the StorageClass created is set as a default, however an OpenShift administrator can define multiple storage classes corresponding to different QoS requirements and other factors based upon their applications. Trident selects a storage backend that can satisfy all the criteria specified in the parameters section in the storage class definition. End users can then provision storage as needed, without administrative intervention. |
