3. Download CA Certificate from RHV: NetApp HCI for Red Hat OpenShift on RHV
To download the CA certificate from RHV, complete the following steps:
In order to access the RHV manager from the RHEL machine during the deployment process, the CA certificate trust must be updated on the machine to trust connections to RHV-M. To download the RHV Manager's CA certificate, run the following commands:
sudo curl -k 'https://<engine-fqdn>/ovirt-engine/services/pki-resource?resource=ca-certificate&format=X509-PEM-CA' -o /tmp/ca.pem [user@rhel7 ~]$ sudo curl -k 'https://rhv-m.cie.netapp.com/ovirt-engine/services/pki-resource?resource=ca-certificate&format=X509-PEM-CA' -o /tmp/ca.pem % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 1376 100 1376 0 0 9685 0 --:--:-- --:--:-- --:--:-- 9690 -
Copy the CA certificate to the directory for server certificates and update the CA trust.
[user@rhel7 ~]$ sudo cp /tmp/ca.pem /etc/pki/ca-trust/source/anchors/ca.pem [user@rhel7 ~]$ sudo update-ca-trust
