2. Download OpenShift Installation Files: NetApp HCI for Red Hat OpenShift on RHV
To download the OpenShift installation files, complete the following steps:
Go to the Red Hat login page and log in with your Red Hat credentials.
On the Clusters page, click Create Cluster.
Select OpenShift Container Platform.
Select Run on Red Hat Virtualization.
The next page allows you to download the OpenShift installer (available for Linux and MacOS), a unique pull secret that is required to create the
install-configfile and theoccommand-line tools (available for Linux, Windows, and MacOS).Download the files, transfer them to a RHEL administrative workstation from where you can run the OpenShift installation, or download these files directly using wget or curl on a RHEL administrative workstation.
