Set Up the Deployment Jump VM and the Kubernetes Master Node VMs (Manual Deployment)
A Deployment Jump VM running a Linux distribution is used for the following purposes:
Deploying ONTAP Select using an Ansible playbook
Deploying the Kubernetes infrastructure with NVIDIA DeepOps and GPU Operator
Installing and configuring NetApp Trident
Three more VMs running Linux are set up; these VMs are configured as Kubernetes Master Nodes in this solution.
Ubuntu 18.04.4 LTS was used in this solution deployment.
Deploy the Ubuntu 18.04.4 LTS VM with VMware tools
You can refer to the high-level steps described in section Install Ubuntu 18.04.4 LTS.
Configure the in-band management network for the VM. See the following sample netplan template:
# This file describes the network interfaces available on your system # For more information, see netplan(5). network: version: 2 renderer: networkd ethernets: ens160: dhcp4: false addresses: [ipv4_address/subnet] routes: - to: 0.0.0.0/0 via: 172.21.232.111 metric: 100 table: 3488 routing-policy: - from: 0.0.0.0/0 priority: 32768 table: 3488 nameservers: addresses: [nameserver_ip] search: [ search_domain ] mtu: 1500
This template is not the only way to setup the network. You can use any other approach that you prefer.
Apply the netplan.
sudo netplan –-debug apply
Stop and disable Network Manager if it is running.
systemctl stop NetworkManager systemctl disable NetworkManager
Open a VI editor to
/etc/iproute2/rt_tables
and add a table entry.# # reserved values # 255 local 254 main 253 default 0 unspec # # local # #1 inr.ruhep 101 3488
Add a host record for the VM in DNS.
Verify outbound internet access.
Update the system.
sudo apt-get update && sudo apt-get upgrade
Reboot the system.
Repeat steps 1 through 9 to set up the other three VMs.
