Deploy NetApp Trident (Automated Deployment)
NetApp Trident is deployed by using an Ansible playbook that is available with NVIDIA DeepOps. Follow these steps to set up NetApp Trident:
From the Deployment Jump VM, navigate to the DeepOps directory and open a VI editor to
config/group_vars/netapp-trident.yml. The file from DeepOps lists two backends and two storage classes. In this solution only one backend and storage class are used.Use the following template to update the file and its parameters (highlighted in yellow) to match your environment.
--- # vars file for netapp-trident playbook # URL of the Trident installer package that you wish to download and use trident_version: "20.07.0"# Version of Trident desired trident_installer_url: "https://github.com/NetApp/trident/releases/download/v{{ trident_version }}/trident-installer-{{ trident_version }}.tar.gz" # Kubernetes version # Note: Do not include patch version, e.g. provide value of 1.16, not 1.16.7. # Note: Versions 1.14 and above are supported when deploying Trident with DeepOps. # If you are using an earlier version, you must deploy Trident manually. k8s_version: 1.17.9# Version of Kubernetes running # Denotes whether or not to create new backends after deploying trident # For more info, refer to: https://netapp-trident.readthedocs.io/en/stable-v20.04/kubernetes/operator-install.html#creating-a-trident-backend create_backends: true # List of backends to create # For more info on parameter values, refer to: https://netapp-trident.readthedocs.io/en/stable-v20.04/kubernetes/operations/tasks/backends/ontap.html # Note: Parameters other than those listed below are not avaible when creating a backend via DeepOps # If you wish to use other parameter values, you must create your backend manually. backends_to_create: - backendName: ontap-flexvol storageDriverName: ontap-nas # only 'ontap-nas' and 'ontap-nas-flexgroup' are supported when creating a backend via DeepOps managementLIF: 172.21.232.118# Cluster Management IP or SVM Mgmt LIF IP dataLIF: 172.21.235.119# NFS LIF IP svm: infra-NFS-hci-ai# Name of SVM username: admin# Username to connect to the ONTAP cluster password: P@ssw0rd# Password to login storagePrefix: trident limitAggregateUsage: "" limitVolumeSize: "" nfsMountOptions: "" defaults: spaceReserve: none snapshotPolicy: none snapshotReserve: 0 splitOnClone: false encryption: false unixPermissions: 777 snapshotDir: false exportPolicy: default securityStyle: unix tieringPolicy: none # Add additional backends as needed # Denotes whether or not to create new StorageClasses for your NetApp storage # For more info, refer to: https://netapp-trident.readthedocs.io/en/stable-v20.04/kubernetes/operator-install.html#creating-a-storage-class create_StorageClasses: true # List of StorageClasses to create # Note: Each item in the list should be an actual K8s StorageClass definition in yaml format # For more info on StorageClass definitions, refer to https://netapp-trident.readthedocs.io/en/stable-v20.04/kubernetes/concepts/objects.html#kubernetes-storageclass-objects. storageClasses_to_create: - apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: ontap-flexvol annotations: storageclass.kubernetes.io/is-default-class: "true" provisioner: csi.trident.netapp.io parameters: backendType: "ontap-nas" # Add additional StorageClasses as needed # Denotes whether or not to copy tridenctl binary to localhost copy_tridentctl_to_localhost: true # Directory that tridentctl will be copied to on localhost tridentctl_copy_to_directory: ../ # will be copied to 'deepops/' directory -
Setup NetApp Trident by using the Ansible playbook.
ansible-playbook -l k8s-cluster playbooks/netapp-trident.yml
Verify that Trident is running.
./tridentctl -n trident version
The expected output is as follows:
rarvind@deployment-jump:~/deepops$ ./tridentctl -n trident version +----------------+----------------+ | SERVER VERSION | CLIENT VERSION | +----------------+----------------+ | 20.07.0 | 20.07.0 | +----------------+----------------+
