11. Install and configure NetApp Trident storage provisioner
Trident is a storage orchestrator for containers. With Trident, microservices and containerized applications can take advantage of enterprise-class storage services provided by the full NetApp portfolio of storage systems for persistent storage mounts. Depending on an application’s requirements, Trident dynamically provisions storage for ONTAP-based products such as NetApp AFF and FAS systems and Element storage systems like NetApp SolidFire and NetApp HCI.
To install Trident on the deployed user cluster and provision a persistent volume, complete the following steps:
The following instructions are screen-capped from a Trident 21.01 install, but the same steps to manually deploy the Trident Operator also apply to the current 21.04 release. |
Download the installation archive to the admin workstation and extract the contents. The current version of Trident is 21.04, which can be downloaded here.
ubuntu@gke-admin-ws-200915-151421:~$ wget https://github.com/NetApp/trident/releases/download/v21.01.0/trident-installer-21.01.0.tar.gz --2021-02-17 12:40:42-- https://github.com/NetApp/trident/releases/download/v21.01.0/trident-installer-21.01.0.tar.gz Resolving github.com (github.com)... 140.82.121.4 Connecting to github.com (github.com)|140.82.121.4|:443... connected. HTTP request sent, awaiting response... 302 Found Location: https://github-releases.githubusercontent.com/77179634/0a63b600-6273-11eb-98df-3d542851f6ff?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210217%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210217T173945Z&X-Amz-Expires=300&X-Amz-Signature=58f26bcac7eeee64673a84d46696490acec357b97a651af42653f973b778ee88&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=77179634&response-content-disposition=attachment%3B%20filename%3Dtrident-installer-21.01.0.tar.gz&response-content-type=application%2Foctet-stream [following] --2021-02-17 12:40:43-- https://github-releases.githubusercontent.com/77179634/0a63b600-6273-11eb-98df-3d542851f6ff?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210217%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210217T173945Z&X-Amz-Expires=300&X-Amz-Signature=58f26bcac7eeee64673a84d46696490acec357b97a651af42653f973b778ee88&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=77179634&response-content-disposition=attachment%3B%20filename%3Dtrident-installer-21.01.0.tar.gz&response-content-type=application%2Foctet-stream Resolving github-releases.githubusercontent.com (github-releases.githubusercontent.com)... 185.199.111.154, 185.199.108.154, 185.199.109.154, ... Connecting to github-releases.githubusercontent.com (github-releases.githubusercontent.com)|185.199.111.154|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 38527217 (37M) [application/octet-stream] Saving to: ‘trident-installer-21.01.0.tar.gz’ 100%[==================================================================================================================>] 38,527,217 84.9MB/s in 0.4s 2021-02-17 12:40:44 (84.9 MB/s) - ‘trident-installer-21.01.0.tar.gz’ saved [38527217/38527217]
Extract the Trident install from the downloaded bundle.
ubuntu@gke-admin-ws-200915-151421:~$ tar -xf trident-installer-21.01.0.tar.gz ubuntu@gke-admin-ws-200915-151421:~$ cd trident-installer
First set the location of the user cluster’s
kubeconfigfile as an environment variable so that you don’t have to reference it, because Trident has no option to pass this file.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ export KUBECONFIG=~/anthos-cluster01-kubeconfig
The
trident-installerdirectory contains manifests for defining all the required resources. Using the appropriate manifests, create theTridentOrchestratorcustom resource definition.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl create -f deploy/crds/trident.netapp.io_tridentorchestrators_crd_post1.16.yaml customresourcedefinition.apiextensions.k8s.io/tridentorchestrators.trident.netapp.io created
If a Trident namespace does not exist, create one in your cluster using the provided manifest.
ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl apply -f deploy/namespace.yaml namespace/trident created
Create the resources required for the Trident operator deployment, such as a
ServiceAccountfor the operator, aClusterRoleandClusterRoleBindingto theServiceAccount, a dedicatedPodSecurityPolicy, or the operator itself.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl create -f deploy/bundle.yaml serviceaccount/trident-operator created clusterrole.rbac.authorization.k8s.io/trident-operator created clusterrolebinding.rbac.authorization.k8s.io/trident-operator created deployment.apps/trident-operator created podsecuritypolicy.policy/tridentoperatorpods created
You can check the status of the operator after it’s deployed with the following commands:
ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl get deployment -n trident NAME READY UP-TO-DATE AVAILABLE AGE trident-operator 1/1 1 1 54s ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl get pods -n trident NAME READY STATUS RESTARTS AGE trident-operator-5c8bbf6754-h957z 1/1 Running 0 68s
With the operator deployed, we can now use it to install Trident. This requires creating a
TridentOrchestrator.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl create -f deploy/crds/tridentorchestrator_cr.yaml tridentorchestrator.trident.netapp.io/trident created ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl describe torc trident Name: trident Namespace: Labels: <none> Annotations: <none> API Version: trident.netapp.io/v1 Kind: TridentOrchestrator Metadata: Creation Timestamp: 2021-02-17T18:25:43Z Generation: 1 Managed Fields: API Version: trident.netapp.io/v1 Fields Type: FieldsV1 fieldsV1: f:spec: .: f:debug: f:namespace: Manager: kubectl Operation: Update Time: 2021-02-17T18:25:43Z API Version: trident.netapp.io/v1 Fields Type: FieldsV1 fieldsV1: f:status: .: f:currentInstallationParams: .: f:IPv6: f:autosupportHostname: f:autosupportImage: f:autosupportProxy: f:autosupportSerialNumber: f:debug: f:enableNodePrep: f:imagePullSecrets: f:imageRegistry: f:k8sTimeout: f:kubeletDir: f:logFormat: f:silenceAutosupport: f:tridentImage: f:message: f:namespace: f:status: f:version: Manager: trident-operator Operation: Update Time: 2021-02-17T18:25:43Z Resource Version: 14836643 Self Link: /apis/trident.netapp.io/v1/tridentorchestrators/trident UID: 0e5f2c3b-6ca2-4b85-8453-0382e1426160 Spec: Debug: true Namespace: trident Status: Current Installation Params: IPv6: Autosupport Hostname: Autosupport Image: Autosupport Proxy: Autosupport Serial Number: Debug: Enable Node Prep: Image Pull Secrets: <nil> Image Registry: k8sTimeout: Kubelet Dir: Log Format: Silence Autosupport: Trident Image: Message: Installing Trident Namespace: trident Status: Installing Version: Events: Type Reason Age From Message ---- ------ ---- ---- ------- Normal Installing 23s trident-operator.netapp.io Installing Trident Normal Installed 15s trident-operator.netapp.io Trident installed -
You can verify that Trident is successfully installed by checking the pods that are running in the namespace or by using the tridentctl binary to check the installed version.
ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl get pod -n trident NAME READY STATUS RESTARTS AGE trident-csi-2cp7x 2/2 Running 0 4m16s trident-csi-2xr5h 2/2 Running 0 4m16s trident-csi-bnwvh 2/2 Running 0 4m16s trident-csi-d6cfc6bb-lxm2p 6/6 Running 0 4m16s trident-operator-5c8bbf6754-h957z 1/1 Running 0 8m55s ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ ./tridentctl -n trident version +----------------+----------------+ | SERVER VERSION | CLIENT VERSION | +----------------+----------------+ | 21.01.1 | 21.01.1 | +----------------+----------------+
The next step in enabling Trident integration with the NetApp HCI solution and Anthos is to create a backend that enables communication with the storage system. NetApp has been validated for several different protocols through the Anthos-ready partner storage validation program. This allows NetApp Trident to provide support in Anthos environments for NFS through our ONTAP platforms and iSCSI from both the ONTAP and Element storage used in NetApp HCI.
A NetApp HCI platform deploys with NetApp Element storage by default. In this guide we configure a backend for this system specifically. In addition to this, a customer can choose to connect to a remote ONTAP storage system or deploy an ONTAP Select software-defined storage system as a virtual appliance in VMware vSphere to provide additional NFS and iSCSI services. The configuration of each of these additional storage backends is beyond the scope of this guide. -
There are sample backend files available in the downloaded installation archive in the
sample-inputfolder. Copybackend-solidfire.jsonto your working directory and edit it to provide information detailing the storage system environment. For Element-based iSCSI connections, copy and edit thebackend-solidfire.jsonfile.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ cp sample-input/backend-solidfire.json ./ ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ $ vi backend-solidfire.json
Edit the user, password, and MVIP value on the EndPoint line.
Edit the SVIP value.
{ "version": 1, "storageDriverName": "solidfire-san", "Endpoint": "https://trident:password@172.21.224.150/json-rpc/8.0", "SVIP": "10.63.172.100:3260", "TenantName": "trident", "Types": [{"Type": "Bronze", "Qos": {"minIOPS": 1000, "maxIOPS": 2000, "burstIOPS": 4000}}, {"Type": "Silver", "Qos": {"minIOPS": 4000, "maxIOPS": 6000, "burstIOPS": 8000}}, {"Type": "Gold", "Qos": {"minIOPS": 6000, "maxIOPS": 8000, "burstIOPS": 10000}}] }
With this backend file in place, run the following command to create your first backend.
ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ ./tridentctl -n trident create backend -f backend.json +-------------------+----------------+--------------------------------------+--------+---------+ | NAME | STORAGE DRIVER | UUID | STATE | VOLUMES | +-------------------+----------------+--------------------------------------+--------+---------+ | solidfire-backend | solidfire-san | a5f9e159-c8f4-4340-a13a-c615fef0f433 | online | 0 | +-------------------+----------------+--------------------------------------+--------+---------+
With the backend created, you must next create a storage class. Just as with the backend, there is a sample storage class file that can be edited for the environment available in the sample-inputs folder. Copy it to the working directory and make necessary edits to reflect the backend created.
ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ cp sample-input/storage-class-csi.yaml.templ ./storage-class-basic.yaml ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ vi storage-class-basic.yaml
The only edit that must be made to this file is to define the
backendTypevalue to the name of the storage driver from the newly created backend. Also note the name-field value that must be referenced in a later step.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: basic-csi provisioner: csi.trident.netapp.io parameters: backendType: "solidfire-san"
Run the
kubectlcommand to create the storage class.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl create -f sample-input/storage-class-basic.yaml
With the storage class created, you must then create the first persistent volume claim (PVC). There is a sample
pvc-basic.yamlfile that can be used to perform this action located in sample-inputs as well. The only edit that must be made to this file is ensuring that the storageClassName field matches the one just created.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ vi sample-input/pvc-basic.yaml kind: PersistentVolumeClaim apiVersion: v1 metadata: name: basic spec: accessModes: - ReadWriteOnce resources: requests: storage: 1Gi storageClassName: basic-csi -
Create the PVC by issuing the
kubectlcommand. Creation can take some time depending on the size of the backing volume being created, so you can watch the process as it completes.ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl create -f sample-input/pvc-basic.yaml ubuntu@gke-admin-ws-200915-151421:~/trident-installer$ kubectl get pvc --watch NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE basic Pending basic 1s basic Pending pvc-2azg0d2c-b13e-12e6-8d5f-5342040d22bf 0 basic 5s basic Bound pvc-2azg0d2c-b13e-12e6-8d5f-5342040d22bf 1Gi RWO basic 7s
