Configure Network Switches (Automated Deployment)
Prepare Required VLAN IDs
The following table lists the necessary VLANs for deployment, as outlined in this solution validation. You should configure these VLANs on the network switches prior to executing NDE.
| Network Segment | Details | VLAN ID |
Out-of-band management network |
Network for HCI terminal user interface (TUI) |
16 |
In-band management network |
Network for accessing management interfaces of nodes, hosts, and guests |
3488 |
VMware vMotion |
Network for live migration of VMs |
3489 |
iSCSI SAN storage |
Network for iSCSI storage traffic |
3490 |
Application |
Network for Application traffic |
3487 |
NFS |
Network for NFS storage traffic |
3491 |
IPL* |
Interpeer link between Mellanox switches |
4000 |
Native |
Native VLAN |
2 |
*Only for Mellanox switches
Switch Configuration
This solution uses Mellanox SN2010 switches running Onyx. The Mellanox switches are configured using an Ansible playbook. Prior to running the Ansible playbook, you should perform the initial configuration of the switches manually:
Install and cable the switches to the uplink switch, compute, and storage nodes.
Power on the switches and configure them with the following details:
Host name
Management IP and gateway
NTP
Log into the Mellanox switches and run the following commands:
configuration write to pre-ansible configuration write to post-ansible
The
pre-ansibleconfiguration file created can be used to restore the switch’s configuration to the state before the Ansible playbook execution.The switch configuration for this solution is stored in the
post-ansibleconfiguration file. -
The configuration playbook for Mellanox switches that follows best practices and requirements for NetApp HCI can be downloaded from the NetApp HCI Toolkit.
The HCI Toolkit also provides a playbook to setup Cisco Nexus switches with similar best practices and requirements for NetApp HCI. Additional guidance on populating the variables and executing the playbook is available in the respective switch README.md file. -
Fill out the credentials to access the switches and variables needed for the environment. The following text is a sample of the variable file for this solution.
# vars file for nar_hci_mellanox_deploy #These set of variables will setup the Mellanox switches for NetApp HCI that uses a 2-cable compute connectivity option. #Ansible connection variables for mellanox ansible_connection: network_cli ansible_network_os: onyx #-------------------- # Primary Variables #-------------------- #Necessary VLANs for Standard NetApp HCI Deployment [native, Management, iSCSI_Storage, vMotion, VM_Network, IPL] #Any additional VLANs can be added to this in the prescribed format below netapp_hci_vlans: - {vlan_id: 2 , vlan_name: "Native" } - {vlan_id: 3488 , vlan_name: "IB-Management" } - {vlan_id: 3490 , vlan_name: "iSCSI_Storage" } - {vlan_id: 3489 , vlan_name: "vMotion" } - {vlan_id: 3491 , vlan_name: "NFS " } - {vlan_id: 3487 , vlan_name: "App_Network" } - {vlan_id: 4000 , vlan_name: "IPL" }#Modify the VLAN IDs to suit your environment #Spanning-tree protocol type for uplink connections. #The valid options are 'network' and 'normal'; selection depends on the uplink switch model. uplink_stp_type: network #---------------------- # IPL variables #---------------------- #Inter-Peer Link Portchannel #ipl_portchannel to be defined in the format - Po100 ipl_portchannel: Po100 #Inter-Peer Link Addresses #The IPL IP address should not be part of the management network. This is typically a private network ipl_ipaddr_a: 10.0.0.1 ipl_ipaddr_b: 10.0.0.2 #Define the subnet mask in CIDR number format. Eg: For subnet /22, use ipl_ip_subnet: 22 ipl_ip_subnet: 24 #Inter-Peer Link Interfaces #members to be defined with Eth in the format. Eg: Eth1/1 peer_link_interfaces: members: ['Eth1/20', 'Eth1/22'] description: "peer link interfaces" #MLAG VIP IP address should be in the same subnet as that of the switches' mgmt0 interface subnet #mlag_vip_ip to be defined in the format - <vip_ip>/<subnet_mask>. Eg: x.x.x.x/y mlag_vip_ip: <<mlag_vip_ip>> #MLAG VIP Domain Name #The mlag domain must be unique name for each mlag domain. #In case you have more than one pair of MLAG switches on the same network, each domain (consist of two switches) should be configured with different name. mlag_domain_name: MLAG-VIP-DOM #--------------------- # Interface Details #--------------------- #Storage Bond10G Interface details #members to be defined with Eth in the format. Eg: Eth1/1 #Only numerical digits between 100 to 1000 allowed for mlag_id #Operational link speed [variable 'speed' below] to be defined in terms of bytes. #For 10 Gigabyte operational speed, define 10G. [Possible values - 10G and 25G] #Interface descriptions append storage node data port numbers assuming all Storage Nodes' Port C -> Mellanox Switch A and all Storage Nodes' Port D -> Mellanox Switch B #List the storage Bond10G interfaces, their description, speed and MLAG IDs in list of dictionaries format storage_interfaces: - {members: "Eth1/1", description: "HCI_Storage_Node_01", mlag_id: 101, speed: 25G} - {members: "Eth1/2", description: "HCI_Storage_Node_02", mlag_id: 102, speed: 25G} #In case of additional storage nodes, add them here #Storage Bond1G Interface #Mention whether or not these Mellanox switches will also be used for Storage Node Mgmt connections #Possible inputs for storage_mgmt are 'yes' and 'no' storage_mgmt: <<yes or no>> #Storage Bond1G (Mgmt) interface details. Only if 'storage_mgmt' is set to 'yes' #Members to be defined with Eth in the format. Eg: Eth1/1 #Interface descriptions append storage node management port numbers assuming all Storage Nodes' Port A -> Mellanox Switch A and all Storage Nodes' Port B -> Mellanox Switch B #List the storage Bond1G interfaces and their description in list of dictionaries format storage_mgmt_interfaces: - {members: "Ethx/y", description: "HCI_Storage_Node_01"} - {members: "Ethx/y", description: "HCI_Storage_Node_02"} #In case of additional storage nodes, add them here #LACP load balancing algorithm for IP hash method #Possible options are: 'destination-mac', 'destination-ip', 'destination-port', 'source-mac', 'source-ip', 'source-port', 'source-destination-mac', 'source-destination-ip', 'source-destination-port' #This variable takes multiple options in a single go #For eg: if you want to configure load to be distributed in the port-channel based on the traffic source and destination IP address and port number, use 'source-destination-ip source-destination-port' #By default, Mellanox sets it to source-destination-mac. Enter the values below only if you intend to configure any other load balancing algorithm #Make sure the load balancing algorithm that is set here is also replicated on the host side #Recommended algorithm is source-destination-ip source-destination-port #Fill the lacp_load_balance variable only if you are using configuring interfaces on compute nodes in bond or LAG with LACP lacp_load_balance: "source-destination-ip source-destination-port" #Compute Interface details #Members to be defined with Eth in the format. Eg: Eth1/1 #Fill the mlag_id field only if you intend to configure interfaces of compute nodes into bond or LAG with LACP #In case you do not intend to configure LACP on interfaces of compute nodes, either leave the mlag_id field unfilled or comment it or enter NA in the mlag_id field #In case you have a mixed architecture where some compute nodes require LACP and some don't, #1. Fill the mlag_id field with appropriate MLAG ID for interfaces that connect to compute nodes requiring LACP #2. Either fill NA or leave the mlag_id field blank or comment it for interfaces connecting to compute nodes that do not require LACP #Only numerical digits between 100 to 1000 allowed for mlag_id. #Operational link speed [variable 'speed' below] to be defined in terms of bytes. #For 10 Gigabyte operational speed, define 10G. [Possible values - 10G and 25G] #Interface descriptions append compute node port numbers assuming all Compute Nodes' Port D -> Mellanox Switch A and all Compute Nodes' Port E -> Mellanox Switch B #List the compute interfaces, their speed, MLAG IDs and their description in list of dictionaries format compute_interfaces: - members: "Eth1/7"#Compute Node for ESXi, setup by NDE description: "HCI_Compute_Node_01" mlag_id: #Fill the mlag_id only if you wish to use LACP on interfaces towards compute nodes speed: 25G - members: "Eth1/8"#Compute Node for ESXi, setup by NDE description: "HCI_Compute_Node_02" mlag_id: #Fill the mlag_id only if you wish to use LACP on interfaces towards compute nodes speed: 25G #In case of additional compute nodes, add them here in the same format as above- members: "Eth1/9"#Compute Node for Kubernetes Worker node description: "HCI_Compute_Node_01" mlag_id: 109 #Fill the mlag_id only if you wish to use LACP on interfaces towards compute nodes speed: 10G - members: "Eth1/10"#Compute Node for Kubernetes Worker node description: "HCI_Compute_Node_02" mlag_id: 110 #Fill the mlag_id only if you wish to use LACP on interfaces towards compute nodes speed: 10G #Uplink Switch LACP support #Possible options are 'yes' and 'no' - Set to 'yes' only if your uplink switch supports LACP uplink_switch_lacp: <<yes or no>> #Uplink Interface details #Members to be defined with Eth in the format. Eg: Eth1/1 #Only numerical digits between 100 to 1000 allowed for mlag_id. #Operational link speed [variable 'speed' below] to be defined in terms of bytes. #For 10 Gigabyte operational speed, define 10G. [Possible values in Mellanox are 1G, 10G and 25G] #List the uplink interfaces, their description, MLAG IDs and their speed in list of dictionaries format uplink_interfaces: - members: "Eth1/18" description_switch_a: "SwitchA:Ethx/y -> Uplink_Switch:Ethx/y" description_switch_b: "SwitchB:Ethx/y -> Uplink_Switch:Ethx/y" mlag_id: 118 #Fill the mlag_id only if 'uplink_switch_lacp' is set to 'yes' speed: 10G mtu: 1500The fingerprint for the switch’s key must match with that present in the host machine from where the playbook is being executed. To ensure this, add the key to /root/. ssh/known_hostor any other appropriate location.
Rollback the Switch Configuration
In case of any timeout failures or partial configuration, run the following command to roll back the switch to the initial state.
configuration switch-to pre-ansible
This operation requires a reboot of the switch. -
Switch the configuration to the state before running the Ansible playbook.
configuration delete post-ansible
Delete the post-ansible file that had the configuration from the Ansible playbook.
Create a new file with the same name post-ansible, write the pre-ansible configuration to it, and switch to the new configuration to restart configuration.
IP Address Requirements
The deployment of the NetApp HCI inferencing platform with VMware and Kubernetes requires multiple IP addresses to be allocated. The following table lists the number of IP addresses required. Unless otherwise indicated, addresses are assigned automatically by NDE.
| IP Address Quantity | Details | VLAN ID | IP Address |
One per storage and compute node* |
HCI terminal user interface (TUI) addresses |
16 |
One per vCenter Server (VM) |
vCenter Server management address |
3488 |
One per management node (VM) |
Management node IP address |
One per ESXi host |
ESXi compute management addresses |
One per storage/witness node |
NetApp HCI storage node management addresses |
One per storage cluster |
Storage cluster management address |
One per ESXi host |
VMware vMotion address |
3489 |
Two per ESXi host |
ESXi host initiator address for iSCSI storage traffic |
3490 |
Two per storage node |
Storage node target address for iSCSI storage traffic |
Two per storage cluster |
Storage cluster target address for iSCSI storage traffic |
Two for mNode |
mNode iSCSI storage access |
The following IPs are assigned manually when the respective components are configured.
One for Deployment Jump Management network |
Deployment Jump VM to execute Ansible playbooks and configure other parts of the system – management connectivity |
3488 |
One per Kubernetes master node – management network |
Kubernetes master node VMs (three nodes) |
3488 |
One per Kubernetes worker node – management network |
Kubernetes worker nodes (two nodes) |
3488 |
One per Kubernetes worker node – NFS network |
3491 |
One per Kubernetes worker node – application network |
3487 |
Three for ONTAP Select – management network |
ONTAP Select VM |
3488 |
One for ONTAP Select – NFS network |
ONTAP Select VM – NFS data traffic |
3491 |
At least two for Triton Inference Server Load Balancer – application network |
Load balancer IP range for Kubernetes load balancer service |
3487 |
*This validation requires the initial setup of the first storage node TUI address. NDE automatically assigns the TUI address for subsequent nodes.
DNS and Timekeeping Requirement
Depending on your deployment, you might need to prepare DNS records for your NetApp HCI system. NetApp HCI requires a valid NTP server for timekeeping; you can use a publicly available time server if you do not have one in your environment.
This validation involves deploying NetApp HCI with a new VMware vCenter Server instance using a fully qualified domain name (FQDN). Before deployment, you must have one Pointer (PTR) record and one Address (A) record created on the DNS server.
