NetApp Solutions
Testing results
We used the TeraSort and TeraValidate scripts in the TeraGen benchmarking tool to measure the Spark performance validation with E5760, E5724, and AFF-A800 configurations. In addition, three major use cases were tested: Spark NLP pipelines and TensorFlow distributed training, Horovod distributed training, and multi-worker deep learning using Keras for CTR Prediction with DeepFM.
For both E-Series and StorageGRID validation, we used Hadoop replication factor 2. For AFF validation, we only used one source of data.
The following table lists the hardware configuration for the Spark performance validation.
Type Hadoop worker nodes Drive type Drives per node Storage controller
SG6060
4
SAS
12
Single high-availability (HA) pair
E5760
4
SAS
60
Single HA pair
E5724
4
SAS
24
Single HA pair
AFF800
4
SSD
6
Single HA pair
The following table lists software requirements.
Software Version
RHEL
7.9
OpenJDK Runtime Environment
1.8.0
OpenJDK 64-Bit Server VM
25.302
Git
2.24.1
GCC/G++
11.2.1
Spark
3.2.1
PySpark
3.1.2
SparkNLP
3.4.2
TensorFlow
2.9.0
Keras
2.9.0
Horovod
0.24.3
Financial sentiment analysis
We published TR-4910: Sentiment Analysis from Customer Communications with NetApp AI, in which an end-to-end conversational AI pipeline was built using the NetApp DataOps Toolkit, AFF storage, and NVIDIA DGX System. The pipeline performs batch audio signal processing, automatic speech recognition (ASR), transfer learning, and sentiment analysis leveraging the DataOps Toolkit, NVIDIA Riva SDK, and the Tao framework. Expanding the sentiment analysis use case to the financial services industry, we built a SparkNLP workflow, loaded three BERT models for various NLP tasks, such as named entity recognition, and obtained sentence-level sentiment for NASDAQ Top 10 companies’ quarterly earnings calls.
The following script sentiment_analysis_spark. py uses the FinBERT model to process transcripts in HDFS and produce positive, neutral, and negative sentiment counts, as shown in the following table:
-bash-4.2$ time ~/anaconda3/bin/spark-submit
--packages com.johnsnowlabs.nlp:spark-nlp_2.12:3.4.3
--master yarn
--executor-memory 5g
--executor-cores 1
--num-executors 160
--conf spark.driver.extraJavaOptions="-Xss10m -XX:MaxPermSize=1024M"
--conf spark.executor.extraJavaOptions="-Xss10m -XX:MaxPermSize=512M"
/sparkusecase/tr-4570-nlp/sentiment_analysis_spark.py hdfs:///data1/Transcripts/
> ./sentiment_analysis_hdfs.log 2>&1
real13m14.300s
user557m11.319s
sys4m47.676s
The following table lists the earnings-call, sentence-level sentiment analysis for NASDAQ Top 10 companies from 2016 to 2020.
Sentiment counts and percentage All 10 Companies AAPL AMD AMZN CSCO GOOGL INTC MSFT NVDA
Positive counts
7447
1567
743
290
682
826
824
904
417
Neutral counts
64067
6856
7596
5086
6650
5914
6099
5715
6189
Negative counts
1787
253
213
84
189
97
282
202
89
Uncategorized counts
196
0
0
76
0
0
0
1
0
(total counts)
73497
8676
8552
5536
7521
6837
7205
6822
6695
In terms of percentages, most sentences spoken by the CEOs and CFOs are factual and therefore carry neutral sentiment. During an earnings call, analysts ask questions which might convey positive or negative sentiment. It is worth further investigating quantitatively how negative or positive sentiment affect stock prices on the same or next day of trading.
The following table lists the sentence-level sentiment analysis for NASDAQ Top 10 companies, expressed in percentage.
Sentiment percentage All 10 Companies AAPL AMD AMZN CSCO GOOGL INTC MSFT NVDA
Positive
10.13%
18.06%
8.69%
5.24%
9.07%
12.08%
11.44%
13.25%
6.23%
Neutral
87.17%
79.02%
88.82%
91.87%
88.42%
86.50%
84.65%
83.77%
92.44%
Negative
2.43%
2.92%
2.49%
1.52%
2.51%
1.42%
3.91%
2.96%
1.33%
Uncategorized
0.27%
0%
0%
1.37%
0%
0%
0%
0.01%
0%
In terms of the workflow runtime, we saw a significant 4.78x improvement from local mode to a distributed environment in HDFS, and a further 0.14% improvement by leveraging NFS.
--master yarn
--executor-cores 1
--num-executors 160
/sparkusecase/tr-4570-nlp/sentiment_analysis_spark.py file:///sparkdemo/sparknlp/Transcripts/
> ./sentiment_analysis_nfs.log 2>&1
real13m13.149s
user537m50.148s
sys4m46.173s
As the following figure shows, data and model parallelism improved the data processing and distributed TensorFlow model inferencing speed. Data location in NFS yielded a slightly better runtime because the workflow bottleneck is the downloading of pretrained models. If we increase the transcripts dataset size, the advantage of NFS is more obvious.
Spark NLP sentiment analysis end-to-end workflow runtime.
Distributed training with Horovod performance
The following command produced runtime information and a log file in our Spark cluster using a single master node with 160 executors each with one core. The executor memory was limited to 5GB to avoid out-of-memory error. See the section “Python scripts for each major use case” for more detail regarding the data processing, model training, and model accuracy calculation in keras_spark_horovod_rossmann_estimator.py.
(base) [root@n138 horovod]# time spark-submit
--master local
--executor-cores 1
--num-executors 160
/sparkusecase/horovod/keras_spark_horovod_rossmann_estimator.py
--epochs 10
--data-dir file:///sparkusecase/horovod
--local-submission-csv /tmp/submission_0.csv
--local-checkpoint-file /tmp/checkpoint/
> /tmp/keras_spark_horovod_rossmann_estimator_local. log 2>&1
The resulting runtime with ten training epochs was as follows:
real43m34.608s
user12m22.057s
sys2m30.127s
It took more than 43 minutes to process input data, train a DNN model, calculate accuracy, and produce TensorFlow checkpoints and a CSV file for prediction results. We limited the number of training epochs to 10, which in practice is often set to 100 to ensure satisfactory model accuracy. The training time typically scales linearly with the number of epochs.
We next used the four worker nodes available in the cluster and executed the same script in yarn mode with data in HDFS:
--master yarn
--executor-cores 1 --num-executors 160 /sparkusecase/horovod/keras_spark_horovod_rossmann_estimator.py
--epochs 10
--data-dir hdfs:///user/hdfs/tr-4570/experiments/horovod
--local-submission-csv /tmp/submission_1.csv
> /tmp/keras_spark_horovod_rossmann_estimator_yarn.log 2>&1
The resulting runtime was improved as follows:
real8m13.728s
user7m48.421s
sys1m26.063s
With Horovod’s model and data parallelism in Spark, we saw a 5.29x runtime speedup of yarn versus local mode with ten training epochs. This is shown in the following figure with the legends HDFS and Local. The underlying TensorFlow DNN model training can be further accelerated with GPUs if available. We plan to conduct this testing and publish results in a future technical report.
Our next test compared the runtimes with input data residing in NFS versus HDFS. The NFS volume on the AFF A800 was mounted on /sparkdemo/horovod across the five nodes (one master, four workers) in our Spark cluster. We ran a similar command as for previous tests, with the --data- dir parameter now pointing to the NFS mount:
--master yarn
--executor-cores 1
--num-executors 160
--epochs 10
--data-dir file:///sparkdemo/horovod
--local-submission-csv /tmp/submission_2.csv
> /tmp/keras_spark_horovod_rossmann_estimator_nfs.log 2>&1
The resulting runtime with NFS was as follows:
real 5m46.229s
user 5m35.693s
sys  1m5.615s
There was a further 1.43x speedup, as shown in the following figure. Therefore, with a NetApp all-flash storage connected to their cluster, customers enjoy the benefits of fast data transfer and distribution for Horovod Spark workflows, achieving 7.55x speedup versus running on a single node.
Horovod Spark Workflow Runtime.
Deep learning models for CTR prediction performance
For recommender systems designed to maximize CTR, you must learn sophisticated feature interactions behind user behaviors that can be mathematically calculated from low order to high order. Both low-order and high-order feature interactions should be equally important for a good deep learning model without biasing towards one or the other. Deep Factorization Machine (DeepFM), a factorization machine-based neural network, combines factorization machines for recommendation and deep learning for feature learning in a new neural network architecture.
Although conventional factorization machines model pairwise feature interactions as an inner product of latent vectors between features and can theoretically capture high-order information, in practice, machine learning practitioners usually only use second- order feature interactions due to the high computation and storage complexity. Deep neural network variants like Google’s Wide & Deep Models on the other hand learns sophisticated feature interactions in a hybrid network structure by combining a linear wide model and a deep model.
There are two inputs to this Wide & Deep Model, one for the underlying wide model and the other for the deep, the latter part of which still requires expert feature engineering and thus renders the technique less generalizable to other domains. Unlike the Wide & Deep Model, DeepFM can be efficiently trained with raw features without any feature engineering because its wide part and deep part share the same input and the embedding vector.
We first processed the Criteo train.txt (11GB) file into a CSV file named ctr_train.csv stored in an NFS mount /sparkdemo/tr-4570-data using run_classification_criteo_spark.py from the section “Python scripts for each major use case.” Within this script, the function process_input_file performs several string methods to remove tabs and insert ‘,’ as the delimiter and ‘\n’ as newline. Note that you only need to process the original train.txt once, so that the code block is shown as comments.
For the following testing of different DL models, we used ctr_train.csv as the input file. In subsequent testing runs, the input CSV file was read into a Spark DataFrame with schema containing a field of ‘label’, integer dense features ['I1', 'I2', 'I3', …, 'I13'], and sparse features ['C1', 'C2', 'C3', …, 'C26']. The following spark-submit command takes in an input CSV, trains DeepFM models with 20% split for cross validation, and picks the best model after ten training epochs to calculate prediction accuracy on the testing set:
(base) [root@n138 ~]# time spark-submit --master yarn --executor-memory 5g --executor-cores 1 --num-executors 160 /sparkusecase/DeepCTR/examples/run_classification_criteo_spark.py --data-dir file:///sparkdemo/tr-4570-data > /tmp/run_classification_criteo_spark_local.log 2>&1
Note that since the data file ctr_train.csv is over 11GB, you must set a sufficient spark.driver.maxResultSize greater than the dataset size to avoid error.
 spark = SparkSession.builder \
    .master("yarn") \
    .appName("deep_ctr_classification") \
    .config("spark.jars.packages", "io.github.ravwojdyla:spark-schema-utils_2.12:0.1.0") \
    .config("spark.executor.cores", "1") \
    .config('spark.executor.memory', '5gb') \
    .config('spark.executor.memoryOverhead', '1500') \
    .config('spark.driver.memoryOverhead', '1500') \
    .config("spark.sql.shuffle.partitions", "480") \
    .config("spark.sql.execution.arrow.enabled", "true") \
    .config("spark.driver.maxResultSize", "50gb") \
    .getOrCreate()
In the above SparkSession.builder configuration we also enabled Apache Arrow, which converts a Spark DataFrame into a Pandas DataFrame with the df.toPandas() method.
22/06/17 15:56:21 INFO scheduler.DAGScheduler: Job 2 finished: toPandas at /sparkusecase/DeepCTR/examples/run_classification_criteo_spark.py:96, took 627.126487 s
Obtained Spark DF and transformed to Pandas DF using Arrow.
After random splitting, there are over 36M rows in the training dataset and 9M samples in the testing set:
Training dataset size =  36672493
Testing dataset size =  9168124
Because this technical report is focused on CPU testing without using any GPUs, it is imperative that you build TensorFlow with appropriate compiler flags. This step avoids invoking any GPU-accelerated libraries and takes full advantage of TensorFlow’s Advanced Vector Extensions (AVX) and AVX2 instructions. These features are designed for linear algebraic computations like vectorized addition, matrix multiplications inside a feed-forward, or back-propagation DNN training. Fused Multiply Add (FMA) instruction available with AVX2 using 256-bit floating point (FP) registers is ideal for integer code and data types, resulting in up to a 2x speedup. For FP code and data types, AVX2 achieves 8% speedup over AVX.
2022-06-18 07:19:20.101478: I tensorflow/core/platform/cpu_feature_guard.cc:151] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations:  AVX2 FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
To build TensorFlow from source, NetApp recommends using Bazel. For our environment, we executed the following commands in the shell prompt to install dnf, dnf-plugins, and Bazel.
yum install dnf
dnf install 'dnf-command(copr)'
dnf copr enable vbatts/bazel
dnf install bazel5
You must enable GCC 5 or newer to use C++17 features during the build process, which is provided by RHEL with Software Collections Library (SCL). The following commands install devtoolset and GCC 11.2.1 on our RHEL 7.9 cluster:
subscription-manager repos --enable rhel-server-rhscl-7-rpms
yum install devtoolset-11-toolchain
yum install devtoolset-11-gcc-c++
yum update
scl enable devtoolset-11 bash
. /opt/rh/devtoolset-11/enable
Note that the last two commands enable devtoolset-11, which uses /opt/rh/devtoolset-11/root/usr/bin/gcc (GCC 11.2.1). Also, make sure your git version is greater than 1.8.3 (this comes with RHEL 7.9). Refer to this article for updating git to 2.24.1.
We assume that you have already cloned the latest TensorFlow master repo. Then create a workspace directory with a WORKSPACE file to build TensorFlow from source with AVX, AVX2, and FMA. Run the configure file and specify the correct Python binary location. CUDA is disabled for our testing because we did not use a GPU. A .bazelrc file is generated according to your settings. Further, we edited the file and set build --define=no_hdfs_support=false to enable HDFS support. Refer to .bazelrc in the section “Python scripts for each major use case,” for a complete list of settings and flags.
./configure
bazel build -c opt --copt=-mavx --copt=-mavx2 --copt=-mfma --copt=-mfpmath=both -k //tensorflow/tools/pip_package:build_pip_package
After you build TensorFlow with the correct flags, run the following script to process the Criteo Display Ads dataset, train a DeepFM model, and calculate the Area Under the Receiver Operating Characteristic Curve (ROC AUC) from prediction scores.
(base) [root@n138 examples]# ~/anaconda3/bin/spark-submit
--master yarn
--executor-memory 15g
--executor-cores 1
--num-executors 160
> . /run_classification_criteo_spark_nfs.log 2>&1
After ten training epochs, we obtained the AUC score on the testing dataset:
Epoch 1/10
125/125 - 7s - loss: 0.4976 - binary_crossentropy: 0.4974 - val_loss: 0.4629 - val_binary_crossentropy: 0.4624
Epoch 2/10
125/125 - 1s - loss: 0.3281 - binary_crossentropy: 0.3271 - val_loss: 0.5146 - val_binary_crossentropy: 0.5130
Epoch 3/10
125/125 - 1s - loss: 0.1948 - binary_crossentropy: 0.1928 - val_loss: 0.6166 - val_binary_crossentropy: 0.6144
Epoch 4/10
125/125 - 1s - loss: 0.1408 - binary_crossentropy: 0.1383 - val_loss: 0.7261 - val_binary_crossentropy: 0.7235
Epoch 5/10
125/125 - 1s - loss: 0.1129 - binary_crossentropy: 0.1102 - val_loss: 0.7961 - val_binary_crossentropy: 0.7934
Epoch 6/10
125/125 - 1s - loss: 0.0949 - binary_crossentropy: 0.0921 - val_loss: 0.9502 - val_binary_crossentropy: 0.9474
Epoch 7/10
125/125 - 1s - loss: 0.0778 - binary_crossentropy: 0.0750 - val_loss: 1.1329 - val_binary_crossentropy: 1.1301
Epoch 8/10
125/125 - 1s - loss: 0.0651 - binary_crossentropy: 0.0622 - val_loss: 1.3794 - val_binary_crossentropy: 1.3766
Epoch 9/10
125/125 - 1s - loss: 0.0555 - binary_crossentropy: 0.0527 - val_loss: 1.6115 - val_binary_crossentropy: 1.6087
Epoch 10/10
125/125 - 1s - loss: 0.0470 - binary_crossentropy: 0.0442 - val_loss: 1.6768 - val_binary_crossentropy: 1.6740
test AUC 0.6337
In a manner similar to previous use cases, we compared the Spark workflow runtime with data residing in different locations. The following figure shows a comparison of the deep learning CTR prediction for a Spark workflows runtime.
Comparison of the deep learning CTR prediction for a Spark workflows runtime.
