Learn about the Proxmox Virtual Environment
Contributors sureshthoppay netapp-jsnyder kevin-hoke
Proxmox Virtual Environment (VE) is an open-source Type-1 hypervisor based on Debian Linux, capable of hosting both VMs and Linux containers (LXC). Learn about Proxmox VE, including its support for full VM and container-based virtualization, cluster management, compute and storage options, networking capabilities, monitoring tools, and data protection strategies.
Overview
Proxmox Virtual Environment(VE) supports both full VM and container based virtualization on the same host. Kernel-based Virtual Machine (KVM) and Quick Emulator (QEMU) is utilized for full VM virtualization. QEMU is an open source machine emulator and virtualizer and it uses KVM Kernel module to execute guest code directly on the host CPU. Linux Containers (LXC) allows containers to be managed like VMs with data persistance across the reboots. With Proxmox VE 9 and later, OCI registry support is included to pull container images from public and private registries. Application container support is added as Technology Preview in Proxmox VE 9.
VM and LXC on Proxmox host
RESTful API is available for automation tasks. For info on API calls, check Proxmox VE api viewer
Cluster Management
The web based management portal is available on the Proxmox VE node at port 8006. A collection of nodes can be joined together to form a cluster. The Proxmox VE configuration, /etc/pve, is shared among all nodes of the cluster. Proxmox VE uses Corosync cluster engine to manage the cluster. The management portal can be accessed from any node of the cluster.
Management Interface
A cluster enables VMs and Containers to be monitored and restarted on other nodes if the hosting node fails. VMs and container needs to be configured for High Availability (HA). VMs and Containers can be hosted on a specific subset of hosts by creating affinity groups. The VM or container is hosted on a host with the highest priority. For more info, check HA manager
HA Group priority
Authentication options include Linux PAM, Proxmox VE PAM, LDAP, Microsoft AD or OpenID. Permissions can be assigned via Roles and the use of resource pools which are a collection of resources. For additional details, check Proxmox User Management
Tip Connection credentials of LDAP/Microsoft AD might be stored in clear text, and in a file which needs to be protected by the host filesystem.
For managing multiple Proxmox VE Clusters, Proxmox Datacenter Manager product is available as a separate installation. It provides a single pane of glass to manage multiple Proxmox VE clusters and Proxmox Backup Servers. It does allow to migrate VMs and containers across clusters.
Customers with an active Basic, Standard, or Premium subscription for their Proxmox remotes gain access to the Proxmox Datacenter Manager Enterprise Repository and technical support.
Compute
The CPU options for a VM includes the number of CPU cores and sockets (to specify the number of vCPUs), option to choose NUMA, defining affinity, setting the limits, and the CPU type.
VM CPU options
For guidance on CPU types and how it affects live migration, check QEMU/KVM Virtual Machine section of Proxmox VE documentation
The CPU options for LXC container image is shown in the following screenshot.
LXC CPU options
The VM and LXC can specify the memory size. For VMs, the balooning feature is available for Linux VMs. For more info, refer to QEMU/KVM Virtual Machine section of Proxmox VE documentation
Storage
A virtual machine consists of a configuration file, /etc/pve/qemu-server/<vm id>.conf, and virtual disk components. Supported virtual disk formats are raw, qcow2 and VMDK. QCOW2 can provide thin provisioning and snapshot capabilities on various storage types.
VM disk formats
There is an option to present the iSCSI LUNs to a VM as raw devices.
Proxmox VE 9 and later supports thin provisioning and space reclamation (UNMAP) with iSCSI and FC storage types. For more details, refer to Proxmox VE Storage
LXC also has its own configuration file, /etc/pve/lxc/<container id>.conf, and container disk components. The data volume can be mounted from the supported storage types.
Container additional mount
Supported storage types include local disk, NAS (SMB and NFS), and SAN (FC, iSCSI, NVMe-oF, etc.). For more details, refer to Proxmox VE Storage
Every storage volume is configured with allowed content types. NAS volumes supports all content types while SAN support is limited to VM and Container images. Directory storage type also supports all content types.
Note SMB connection credentials are stored in clear text and are accessible only to root.
Content types with NAS
Content types with SAN
To import VMs from a Broadcom vSphere environment, the vSphere host can also be included as a storage device.
Network
Proxmox VE supports both host based networking and cluster wide VNets using native Linux networking features like Linux bridge and Open vSwitch, to implement Software Defined Networking (SDN). The Ethernet interfaces on the host can be bonded together to provide fault tolerance and high availability. For other options, refer to Proxmox VE documentation
Bonded network
Guest networks can be configured at the cluster level and changes are pushed to member hosts. Separation is managed with Zones, VNets and Subnets. Zone defines the network types such as Simple (isolated with source nat), VLAN (802.1Q - external switch dependency), VLAN Stacking (802.1ad - private vlan), VXLAN (Layer 2 over Layer 3. For VPC like networking), EVPN (VXLAN with BGP to create Layer 3 Multi-cluster network), etc.
Depending on the type of zone, the network behaves differently and offers specific features, advantages, and limitations.
Use cases for SDN range from an isolated private network on each individual node, to complex overlay networks across multiple PVE clusters on different locations.
After configuring a VNet in the cluster-wide datacenter SDN administration interface, it is available as a common Linux bridge, locally on each node, to be assigned to VMs and Containers.
When a VM is created, the user has capability to pick the Linux bridge to connect. Additional interfaces can be included after the VM is created.
VM network selection
And here is the VNet information at the datacenter level.
VNet infomation at datacenter
Monitoring
The summary page on most of the objects, such as Datacenter, host, VM, container, storage, etc. provides details and includes some performance metrics. The following screenshot shows the summary page of a host and includes information about the packages installed.
Host package view
The stats about hosts, guests, storage, etc. can be pushed to an external Graphite or Influxdb database. For details, refer to Proxmox VE documentation.
Data Protection
Proxmox VE includes options to backup and restore the VMs and Containers to storage configured for backup content. Backups can be initiated from UI or CLI using the tool vzdump or it can be scheduled. For more details, refer to Backup and Restore section of Proxmox VE documentation.
Proxmox VE backup storage content
The backup content needs to be stored offsite to protect from any diaster at source site.
Veeam added support for Proxmox VE with version 12.2. This allows restore of VM backups from vSphere to a Proxmox VE host.
