Troubleshooting
PDF of this doc site
Artificial Intelligence
Containers
Red Hat OpenShift with NetApp
Creating your file...
Your file is ready
Error 1: XCP Failed with nfs3 error 70: stale filehandle Error in the xcp.log
Reason and guidance.
Mount the source folder and verify that the folder exists. If it does not exist or if it has been removed, you will receive a stale filehandle
error, in which case, you can ignore the error.
Error 2: NetApp NFS Destination Volume Has Space, but XCP Failed with nfs3 error 28: no space left on device
Check the space of the NFS destination volume by running the
df
command or check the storage.root@workr-140: USER3# df -h /xcpdest Filesystem Size Used Avail Use% Mounted on 10.63.150.127:/xcpsrc_vol 4.3T 1.7T 2.6T 40% /xcpsrc_vol
Check the inodes in the storage controller.
A800-Node1-2::> volume show -volume xcpdest -fields files,files-used vserver volume files files-used -------------- ------- -------- ---------- A800-Node1_vs1 xcpdest 21251126 21251126 A800-Node1-2::>
If inode is used, increase the number of inodes by running the following command:
A800-Node1-2::> volume modify -volume xcpdest -vserver A800-Node1_vs1 -files 40000000 Volume modify successful on volume xcpdest of Vserver A800-Node1_vs1. A800-Node1-2::> volume show -volume xcpdest -fields files,files-used vserver volume files files-used -------------- ------- -------- ---------- A800-Node1_vs1 xcpdest 39999990 21251126 A800-Node1-2::>
