Data migration from 7-Mode to ONTAP
This section provides detailed steps for migrating data from NetApp Data ONTAP operating in 7-Mode to ONTAP.
Transitioning 7-Mode NFSv3 storage to ONTAP for NFS data
This section provides the step-by-step procedure in the following table for transitioning a source 7-Mode NFSv3 export to an ONTAP system.
NetApp assumes that the source 7-Mode NFSv3 volume is exported and mounted on the client system and that XCP is already installed on a Linux system.
Verify that the target ONTAP system is healthy.
CLUSTER::> cluster show Node Health Eligibility --------------------- ------- ------------ CLUSTER-01 true true CLUSTER-02 true true 2 entries were displayed. CLUSTER::> node show Node Health Eligibility Uptime Model Owner Location --------- ------ ----------- ------------- ----------- -------- --------------- CLUSTER-01 true true 78 days 21:01 FAS8060 RTP CLUSTER-02 true true 78 days 20:50 FAS8060 RTP 2 entries were displayed. CLUSTER::> storage failover show Takeover Node Partner Possible State Description -------------- -------------- -------- ------------------------------------- CLUSTER-01 CLUSTER-02 true Connected to CLUSTER-02 CLUSTER-02 CLUSTER-01 true Connected to CLUSTER-01 2 entries were displayed. -
Verify that at least one nonroot aggregate exists on the target system. The aggregate is normal.
CLUSTER::> storage aggregate show Aggregate Size Available Used% State #Vols Nodes RAID Status --------- -------- --------- ----- ------- ------ ---------------- ------------ aggr0 368.4GB 17.85GB 95% online 1 CLUSTER-01 raid_dp, normal aggr0_CLUSTER_02_0 368.4GB 17.85GB 95% online 1 CLUSTER-02 raid_dp, normal source 1.23TB 1.10TB 11% online 6 CLUSTER-01 raid_dp, normal 3 entries were displayed.If there is no data aggregate, create a new one using the
storage aggr createcommand. -
Create a storage virtual machine (SVM) on the target cluster system.
CLUSTER::> vserver create -vserver dest -rootvolume dest_root -aggregate poc -rootvolume-security-style mixed [Job 647] Job succeeded: Vserver creation completed Verify the security style and language settings of the source Verify that the SVM was successfully created. CLUSTER::> vserver show -vserver dest Vserver: dest Vserver Type: data Vserver Subtype: default Vserver UUID: 91f6d786-0063-11e5-b114-00a09853a969 Root Volume: dest_root Aggregate: poc NIS Domain: - Root Volume Security Style: mixed LDAP Client: - Default Volume Language Code: C.UTF-8 Snapshot Policy: default Comment: Quota Policy: default List of Aggregates Assigned: - Limit on Maximum Number of Volumes allowed: unlimited Vserver Admin State: running Vserver Operational State: running Vserver Operational State Stopped Reason: - Allowed Protocols: nfs, cifs, fcp, iscsi, ndmp Disallowed Protocols: - Is Vserver with Infinite Volume: false QoS Policy Group: - Config Lock: false IPspace Name: Default -
Remove the FCP, iSCSI, NDMP, and CIDS protocols from the target SVM.
CLUSTER::> vserver remove-protocols -vserver dest -protocols fcp,iscsi,ndmp,cifs
Verify that NFS is the allowed protocol for this SVM.
CLUSTER::> vserver show -vserver dest -fields allowed-protocols vserver allowed-protocols ------- ----------------- dest nfs
Create a new read-write data volume on the destination SVM. Verify that the security style, language settings, and capacity requirements match the source volume.
CLUSTER::> vol create -vserver dest -volume dest_nfs -aggregate poc -size 150g -type RW -state online -security-style mixed [Job 648] Job succeeded: Successful
Create a data LIF to serve NFS client requests.
CLUSTER::> network interface create -vserver dest -lif dest_lif -address 10.61.73.115 -netmask 255.255.255.0 -role data -data-protocol nfs -home-node CLUSTER-01 -home-port e0l
Verify that the LIF was successfully created.
CLUSTER::> network interface show -vserver dest Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- dest dest_lif up/up 10.61.73.113/24 CLUSTER-01 e0i true -
Create a static route with the SVM, if required.
CLUSTER::> network route create -vserver dest -destination 0.0.0.0/0 -gateway 192.168.100.111
Verify that the route was successfully created.
CLUSTER::> network route show -vserver source Vserver Destination Gateway Metric ------------------- --------------- --------------- ------ dest 0.0.0.0/0 10.61.73.1 20 -
Mount the target NFS data volume in the SVM namespace.
CLUSTER::> volume mount -vserver dest -volume dest_nfs -junction-path /dest_nfs -active true
Verify that the volume is successfully mounted.
CLUSTER::> volume show -vserver dest -fields junction-path vserver volume junction-path ------- -------- ------------- dest dest_nfs /dest_nfs dest dest_root / 2 entries were displayed.You can also specify volume mount options (junction path) with the
volume createcommand. -
Start the NFS service on the target SVM.
CLUSTER::> vserver nfs start -vserver dest
Verify that the service is started and running.
CLUSTER::> vserver nfs status The NFS server is running on Vserver "dest". CLUSTER::> nfs show Vserver: dest General Access: true v3: enabled v4.0: disabled 4.1: disabled UDP: enabled TCP: enabled Default Windows User: - Default Windows Group: - -
Verify that the default NFS export policy was applied to the target SVM.
CLUSTER::> vserver export-policy show -vserver dest Vserver Policy Name --------------- ------------------- dest default
If required, create a new custom export policy for the target SVM.
CLUSTER::> vserver export-policy create -vserver dest -policyname xcpexportpolicy
Verify that the new custom export policy was successfully created.
CLUSTER::> vserver export-policy show -vserver dest Vserver Policy Name --------------- ------------------- dest default dest xcpexportpolicy 2 entries were displayed.
Modify the export policy rules to allow access to NFS clients.
CLUSTER::> export-policy rule modify -vserver dest -ruleindex 1 -policyname xcpexportpolicy -clientmatch 0.0.0.0/0 -rorule any -rwrule any -anon 0 Verify the policy rules have modified CLUSTER::> export-policy rule show -instance Vserver: dest Policy Name: xcpexportpolicy Rule Index: 1 Access Protocol: nfs3 Client Match Hostname, IP Address, Netgroup, or Domain: 0.0.0.0/0 RO Access Rule: none RW Access Rule: none User ID To Which Anonymous Users Are Mapped: 65534 Superuser Security Types: none Honor SetUID Bits in SETATTR: true Allow Creation of Devices: true -
Verify that the client is allowed access to the volume.
CLUSTER::> export-policy check-access -vserver dest -volume dest_nfs -client-ip 10.61.82.215 -authentication-method none -protocol nfs3 -access-type read-write Policy Policy Rule Path Policy Owner Owner Type Index Access ----------------------------- ---------- --------- ---------- ------ ---------- / xcpexportpolicy dest_root volume 1 read /dest_nfs xcpexportpolicy dest_nfs volume 1 read-write 2 entries were displayed. -
Connect to the Linux NFS server. Create a mount point for the NFS exported volume.
[root@localhost /]# cd /mnt [root@localhost mnt]# mkdir dest
Mount the target NFSv3 exported volume at this mount point.
The NFSv3 volumes should be exported but not necessarily mounted by the NFS server. If they can be mounted, the XCP Linux host client mounts these volumes. [root@localhost mnt]# mount -t nfs 10.61.73.115:/dest_nfs /mnt/dest
Verify that the mount point was successfully created.
[root@ localhost /]# mount | grep nfs 10.61.73.115:/dest_nfs on /mnt/dest type nfs (rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.61.82.215,mountvers=3,mountport=4046,mountproto=udp,local_lock=none,addr=10.61.73.115)
Create a test file on the NFS exported mount point to enable read-write access.
[root@localhost dest]# touch test.txt Verify the file is created [root@localhost dest]# ls -l total 0 -rw-r--r-- 1 root bin 0 Jun 2 03:16 test.txt
After the read-write test is complete, delete the file from the target NFS mount point. -
Connect to the Linux client system in which XCP is installed. Browse to the XCP install path.
[root@localhost ~]# cd /linux/ [root@localhost linux]#
Query the source 7-Mode NFSv3 exports by running the
xcp showcommand on the XCP Linux client host system.[root@localhost]#./xcp show 10.61.82.215 == NFS Exports == Mounts Errors Server 4 0 10.61.82.215 Space Files Space Files Free Free Used Used Export 23.7 GiB 778,134 356 KiB 96 10.61.82.215:/vol/nfsvol1 17.5 GiB 622,463 1.46 GiB 117 10.61.82.215:/vol/nfsvol 328 GiB 10.8M 2.86 GiB 7,904 10.61.82.215:/vol/vol0/home 328 GiB 10.8M 2.86 GiB 7,904 10.61.82.215:/vol/vol0 == Attributes of NFS Exports == drwxr-xr-x --- root wheel 4KiB 4KiB 2d21h 10.61.82.215:/vol/nfsvol1 drwxr-xr-x --- root wheel 4KiB 4KiB 2d21h 10.61.82.215:/vol/nfsvol drwxrwxrwx --t root wheel 4KiB 4KiB 9d22h 10.61.82.215:/vol/vol0/home drwxr-xr-x --- root wheel 4KiB 4KiB 4d0h 10.61.82.215:/vol/vol0 3.89 KiB in (5.70 KiB/s), 7.96 KiB out (11.7 KiB/s), 0s. -
Scan the source NFSv3 exported paths and print the statistics of their file structure.
NetApp recommends putting the source NFSv3 exports in read-only mode during xcp
scan,copy, andsyncoperations.[root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol nfsvol nfsvol/n5000-uk9.5.2.1.N1.1.bin nfsvol/821_q_image.tgz nfsvol/822RC2_q_image.tgz nfsvol/NX5010_12_node_RCF_v1.3.txt nfsvol/n5000-uk9-kickstart.5.2.1.N1.1.bin nfsvol/NetApp_CN1610_1.1.0.5.stk nfsvol/glibc-common-2.7-2.x86_64.rpm nfsvol/glibc-2.7-2.x86_64.rpm nfsvol/rhel-server-5.6-x86_64-dvd.iso.filepart nfsvol/xcp nfsvol/xcp_source nfsvol/catalog 23 scanned, 7.79 KiB in (5.52 KiB/s), 1.51 KiB out (1.07 KiB/s), 1s.
Copy the source 7-Mode NFSv3 exports to NFSv3 exports on the target ONTAP system.
[root@localhost /]# ./xcp copy 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs 44 scanned, 39 copied, 264 MiB in (51.9 MiB/s), 262 MiB out (51.5 MiB/s), 5s 44 scanned, 39 copied, 481 MiB in (43.3 MiB/s), 479 MiB out (43.4 MiB/s), 10s 44 scanned, 40 copied, 748 MiB in (51.2 MiB/s), 747 MiB out (51.3 MiB/s), 16s 44 scanned, 40 copied, 1.00 GiB in (55.9 MiB/s), 1.00 GiB out (55.9 MiB/s), 21s 44 scanned, 40 copied, 1.21 GiB in (42.8 MiB/s), 1.21 GiB out (42.8 MiB/s), 26s Sending statistics... 44 scanned, 43 copied, 1.46 GiB in (47.6 MiB/s), 1.45 GiB out (47.6 MiB/s), 31s.
After the copy is finished, verify that the source and destination NFSv3 exports have identical data. Run the
xcp verifycommand.[root@localhost /]# ./xcp verify 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs 44 scanned, 44 found, 28 compared, 27 same data, 2.41 GiB in (98.4 MiB/s), 6.25 MiB out (255 KiB/s), 26s 44 scanned, 44 found, 30 compared, 29 same data, 2.88 GiB in (96.4 MiB/s), 7.46 MiB out (249 KiB/s), 31s 44 scanned, 100% found (43 have data), 43 compared, 100% verified (data, attrs, mods), 2.90 GiB in (92.6 MiB/s), 7.53 MiB out (240 KiB/s), 32s.
If
xcp verifyfinds differences between the source and destination data, then the errorno such file or directoryis reported in the summary. To fix that issue, run thexcp synccommand to copy the source changes to the destination. -
Before and during the cutover, run
verifyagain. If the source has new or updated data, then perform incremental updates. Run thexcp synccommand.For this operation, the previous copy index name or number is required. [root@localhost /]# ./xcp sync -id 3 Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs1'} 64 reviewed, 64 checked at source, 6 changes, 6 modifications, 51.7 KiB in (62.5 KiB/s), 22.7 KiB out (27.5 KiB/s), 0s. xcp: sync '3': Starting search pass for 1 modified directory... xcp: sync '3': Found 6 indexed files in the 1 changed directory xcp: sync '3': Rereading the 1 modified directory to find what's new... xcp: sync '3': Deep scanning the 1 directory that changed... 11 scanned, 11 copied, 12.6KiB in (6.19KiBps), 9.50 KiB out (4.66KiBps), 2s. -
To resume a previously interrupted copy operation, run the
xcp resumecommand.[root@localhost /]# ./xcp resume -id 4 Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs7'} xcp: resume '4': WARNING: Incomplete index. xcp: resume '4': Found 18 completed directories and 1 in progress 106 reviewed, 24.2 KiB in (30.3 KiB/s), 7.23 KiB out (9.06 KiB/s), 0s. xcp: resume '4': Starting second pass for the in-progress directory... xcp: resume '4': Found 3 indexed directories and 0 indexed files in the 1 in-progress directory xcp: resume '4': In progress dirs: unindexed 1, indexed 0 xcp: resume '4': Resuming the 1 in-progress directory... 20 scanned, 7 copied, 205 MiB in (39.6 MiB/s), 205 MiB out (39.6 MiB/s), 5s 20 scanned, 14 copied, 425 MiB in (42.1 MiB/s), 423 MiB out (41.8 MiB/s), 11s 20 scanned, 14 copied, 540 MiB in (23.0 MiB/s), 538 MiB out (23.0 MiB/s), 16s 20 scanned, 14 copied, 721 MiB in (35.6 MiB/s), 720 MiB out (35.6 MiB/s), 21s 20 scanned, 15 copied, 835 MiB in (22.7 MiB/s), 833 MiB out (22.7 MiB/s), 26s 20 scanned, 16 copied, 1007 MiB in (34.3 MiB/s), 1005 MiB out (34.3 MiB/s), 31s 20 scanned, 17 copied, 1.15 GiB in (33.9 MiB/s), 1.15 GiB out (33.9 MiB/s), 36s 20 scanned, 17 copied, 1.27 GiB in (25.5 MiB/s), 1.27 GiB out (25.5 MiB/s), 41s 20 scanned, 17 copied, 1.45 GiB in (36.1 MiB/s), 1.45 GiB out (36.1 MiB/s), 46s 20 scanned, 17 copied, 1.69 GiB in (48.7 MiB/s), 1.69 GiB out (48.7 MiB/s), 51s Sending statistics... 20 scanned, 20 copied, 21 indexed, 1.77 GiB in (33.5 MiB/s), 1.77 GiB out (33.4 MiB/s), 54s.After
resumefinishes copying files, runverifyagain so that the source and destination storage have identical data. -
The NFSv3 client host needs to unmount the source NFSv3 exports provisioned from the 7-Mode storage and mounts the target NFSv3 exports from ONTAP. Cutover requires an outage.
Transitioning 7-Mode volume Snapshot copies to ONTAP
This section covers the procedure for transitioning a source 7-Mode volume NetApp Snapshot copy to ONTAP.
NetApp assumes that the source 7-Mode volume is exported and mounted on the client system and that XCP is already installed on a Linux system. A Snapshot copy is a point-in-time image of a volume that records incremental changes since the last Snapshot copy. Use the -snap option with a 7-Mode system as the source.
Warning: Keep the base Snapshot copy. Do not delete the base Snapshot copy after the baseline copy is complete. The base Snapshot copy is required for further sync operations.
Create an SVM on the target cluster system.
Remove the FCP, iSCSI, NDMP, and CIFS protocols from the target SVM.
CLUSTER::> vserver remove-protocols -vserver dest -protocols fcp,iscsi,ndmp,cifs Verify that NFS is the allowed protocol for this SVM. CLUSTER::> vserver show -vserver dest -fields allowed-protocols vserver allowed-protocols ------- ----------------- dest nfs
If required, create a static route with the SVM.
Verify that the volume was successfully mounted.
CLUSTER::> volume show -vserver dest -fields junction-path vserver volume junction-path ------- -------- ------------- dest dest_nfs /dest_nfs dest dest_root / 2 entries were displayed.You can also specify the volume mount options (junction path) with the
Verify that the default NFS export policy is applied to the target SVM.
Modify the export policy rules to allow access to NFS clients on the target system.
Verify that the client has access to the target volume.
xcp scan,copy, andsyncoperations. Insyncoperation, you must pass the-snapoption with a corresponding value.[root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol/.snapshot/snap1 nfsvol nfsvol/n5000-uk9.5.2.1.N1.1.bin nfsvol/821_q_image.tgz nfsvol/822RC2_q_image.tgz nfsvol/NX5010_12_node_RCF_v1.3.txt nfsvol/n5000-uk9-kickstart.5.2.1.N1.1.bin nfsvol/catalog 23 scanned, 7.79 KiB in (5.52 KiB/s), 1.51 KiB out (1.07 KiB/s), 1s. [root@scspr1202780001 vol_acl4]# ./xcp sync -id 7msnap1 -snap 10.236.66.199:/vol/nfsvol/.snapshot/snap10 (show scan and sync)
Copy the source 7-Mode NFSv3 snapshot (base) to NFSv3 exports on the target ONTAP system.
[root@localhost /]# /xcp copy 10.61.82.215:/vol/nfsvol/.snapshot/snap1 10.61.73.115:/dest_nfs 44 scanned, 39 copied, 264 MiB in (51.9 MiB/s), 262 MiB out (51.5 MiB/s), 5s 44 scanned, 39 copied, 481 MiB in (43.3 MiB/s), 479 MiB out (43.4 MiB/s), 10s 44 scanned, 40 copied, 748 MiB in (51.2 MiB/s), 747 MiB out (51.3 MiB/s), 16s 44 scanned, 40 copied, 1.00 GiB in (55.9 MiB/s), 1.00 GiB out (55.9 MiB/s), 21s 44 scanned, 40 copied, 1.21 GiB in (42.8 MiB/s), 1.21 GiB out (42.8 MiB/s), 26s Sending statistics... 44 scanned, 43 copied, 1.46 GiB in (47.6 MiB/s), 1.45 GiB out (47.6 MiB/s), 31s.
Keep this base snapshot for further sync operations. -
After copy is complete, verify that the source and destination NFSv3 exports have identical data. Run the
If
verifyfinds differences between the source and destination data, then the errorno such file or directory `is reported in the summary. To fix that issue, run the `xcp synccommand to copy the source changes to the destination. -
verifyagain. If the source has new or updated data, then perform incremental updates. If there are incremental changes, create a new Snapshot copy for these changes and pass that snapshot path with the-snapoption for sync operations.Run the
xcp synccommand with the-snapoption and snapshot path.[root@localhost /]# ./xcp sync -id 3 Index: {source: '10.61.82.215:/vol/nfsvol/.snapshot/snap1', target: '10.61.73.115:/dest_nfs1'} 64 reviewed, 64 checked at source, 6 changes, 6 modifications, 51.7 KiB in (62.5 KiB/s), 22.7 KiB out (27.5 KiB/s), 0s. xcp: sync '3': Starting search pass for 1 modified directory... xcp: sync '3': Found 6 indexed files in the 1 changed directory xcp: sync '3': Rereading the 1 modified directory to find what's new... xcp: sync '3': Deep scanning the 1 directory that changed... 11 scanned, 11 copied, 12.6 KiB in (6.19 KiB/s), 9.50 KiB out (4.66 KiB/s), 2s..For this operation, the base snapshot is required. -
xcp resumecommand.[root@scspr1202780001 534h_dest_vol]# ./xcp resume -id 3 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxxxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 xcp: Index: {source: '10.61.82.215:/vol/nfsvol',/.snapshot/snap1, target: 10.237.160.55:/dest_vol} xcp: resume '7msnap_res1': Reviewing the incomplete index... xcp: diff '7msnap_res1': Found 143 completed directories and 230 in progress 39,688 reviewed, 1.28 MiB in (1.84 MiB/s), 13.3 KiB out (19.1 KiB/s), 0s. xcp: resume '7msnap_res1': Starting second pass for the in-progress directories... xcp: resume '7msnap_res1': Resuming the in-progress directories... xcp: resume '7msnap_res1': Resumed command: copy {-newid: u'7msnap_res1'} xcp: resume '7msnap_res1': Current options: {-id: '7msnap_res1'} xcp: resume '7msnap_res1': Merged options: {-id: '7msnap_res1', -newid: u'7msnap_res1'} xcp: resume '7msnap_res1': Values marked with a * include operations before resume 68,848 scanned*, 54,651 copied*, 39,688 indexed*, 35.6 MiB in (7.04 MiB/s), 28.1 MiB out (5.57 MiB/s), 5s -
The NFSv3 client host must unmount the source NFSv3 exports provisioned from the 7-Mode storage and mount the target NFSv3 exports from ONTAP. This cutover requires an outage.
Migrating ACLv4 from NetApp 7-Mode to a NetApp storage system
This section covers the step-by-step procedure for transitioning a source NFSv4 export to an ONTAP system.
NetApp assumes that the source NFSv4 volume is exported and mounted on the client system and that XCP is already installed on a Linux system. The source should be a NetApp 7-Mode system that support ACLs. ACL migration is supported from NetApp to NetApp only. To copy files with a special character in the name, make sure the source and destination support UTF- 8 encoded language. |
Prerequisites for migrating a source NFSv4 export to ONTAP
Before you migrate a source NFSv4 export to ONTAP, the following prerequisites must be met:
The destination system must have NFSv4 configured.
The NFSv4 source and target must be mounted on the XCP host. Select NFS v4.0 to match the source and target storage and verify that the ACLs are enabled on the source and target system.
XCP requires the source/target path to be mounted on the XCP host for ACL processing.In the following example,
vol1(10.63.5.56:/vol1)is mounted on the/mnt/vol1path:
[root@localhost ~]# df -h Filesystem Size Used Avail Use% Mounted on 10.63.5.56:/vol1 973M 4.2M 969M 1% /mnt/vol1 [root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/ XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029 drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1 rw-r--r-- --- root root 4 0 23h42m vol1/DIR1/FILE drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11 drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1 rw-r--r-- --- root root 4 0 23h42m vol1/DIR1/DIR11/FILE drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11/DIR2 rw-r--r-- --- root root 4 0 23h42m vol1/DIR1/DIR11/DIR2/FILE drwxr-xr-x --- root root 4KiB 4KiB 17m43s vol1/DIR1/DIR11/DIR2/DIR22 8 scanned, 8 getacls, 1 v3perm, 7 acls, 3.80 KiB in (3.86 KiB/s), 1.21 KiB out (1.23 KiB/s), 0s.
Subdirectories options
The two options to work with subdirectories are as follows:
For XCP to work on a subdirectory
(/vol1/DIR1/DIR11), mount the complete path (10.63.5.56:/vol1/DIR1/DIR11) on the XCP host.If the complete path is not mounted, XCP reports the following error:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/DIR1/DIR11 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029 xcp: ERROR: For xcp to process ACLs, please mount 10.63.5.56:/vol1/DIR1/DIR11 using the OS nfs4 client.
Use the subdirectory syntax (
mount: subdirectory/qtree/.snapshot), as shown in the example below:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1:/DIR1/DIR11 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029 drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11 rw-r--r-- --- root root 4 0 23h51m DIR11/DIR2/FILE drwxr-xr-x --- root root 4KiB 4KiB 26m9s DIR11/DIR2/DIR22 rw-r--r-- --- root root 4 0 23h51m DIR11/FILE drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11/DIR2 5 scanned, 5 getacls, 5 acls, 2.04 KiB in (3.22 KiB/s), 540 out (850/s), 0s.
Complete the following steps to migrate ACLv4 from NetApp 7-Mode to a NetApp storage system.
CLUSTER::> vserver nfs status The NFS server is running on Vserver "dest". CLUSTER::> nfs show Vserver: dest General Access: true v3: enabled v4.0: enabled 4.1: disabled UDP: enabled TCP: enabled Default Windows User: - Default Windows Group: - -
Check that the default NFS export policy is applied to the target SVM.
Verify that the policy rules have been modified.
Mount the target NFSv4 exported volume at this mount point.
The NFSv4 volumes should be exported but not necessarily mounted by the NFS server. If they can be mounted, the XCP Linux host client mounts these volumes. [root@localhost mnt]# mount -t nfs4 10.63.5.56:/vol1 /mnt/vol1
[root@localhost mnt]# mount | grep nfs 10.63.5.56:/vol1 on /mnt/vol1 type nfs4 (rw,relatime,vers=4.0,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600, retrans=2,sec=sys,clientaddr=10.234.152.84,local_lock=none,addr=10.63.5.56)
Verify the file is created.
Query the source NFSv4 exports by running the
xcp showcommand on the XCP Linux client host system.root@localhost]# ./xcp show 10.63.5.56 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 getting pmap dump from 10.63.5.56 port 111... getting export list from 10.63.5.56... sending 6 mounts and 24 nfs requests to 10.63.5.56... == RPC Services == '10.63.5.56': UDP rpc services: MNT v1/2/3, NFS v3, NLM v4, PMAP v2/3/4, STATUS v1 '10.63.5.56': TCP rpc services: MNT v1/2/3, NFS v3/4, NLM v4, PMAP v2/3/4, STATUS v1 == NFS Exports == Mounts Errors Server 6 0 10.63.5.56 Space Files Space Files Free Free Used Used Export 94.7 MiB 19,883 324 KiB 107 10.63.5.56:/ 971 MiB 31,023 2.19 MiB 99 10.63.5.56:/vol2 970 MiB 31,024 2.83 MiB 98 10.63.5.56:/vol1 9.33 GiB 310,697 172 MiB 590 10.63.5.56:/vol_005 43.3 GiB 1.10M 4.17 GiB 1.00M 10.63.5.56:/vol3 36.4 GiB 1.10M 11.1 GiB 1.00M 10.63.5.56:/vol4 == Attributes of NFS Exports == drwxr-xr-x --- root root 4KiB 4KiB 6d2h 10.63.5.56:/ drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol2 drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol1 drwxr-xr-x --- root root 4KiB 4KiB 9d2h 10.63.5.56:/vol_005 drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol3 drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol4 6.09 KiB in (9.19 KiB/s), 12.2 KiB out (18.3 KiB/s), 0s. -
Scan the source NFSv4 exported paths and print the statistics of their file structure.
NetApp recommends putting the source NFSv4 exports in read-only mode during
xcp scan,copy, andsyncoperations.[root@localhost]# ./xcp scan -acl4 10.63.5.56:/vol1 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 vol1 vol1/test/f1 vol1/test 3 scanned, 3 getacls, 3 v3perms, 1.59 KiB in (1.72 KiB/s), 696 out (753/s), 0s.
Copy source NFSv4 exports to NFSv4 exports on the target ONTAP system.
[root@localhost]# ./xcp copy -acl4 -newid id1 10.63.5.56:/vol1 10.63.5.56:/vol2 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 3 scanned, 2 copied, 3 indexed, 3 getacls, 3 v3perms, 1 setacl, 14.7 KiB in (11.7 KiB/s), 61 KiB out (48.4 KiB/s), 1s..
After
copyis complete, verify that the source and destination NFSv4 exports have identical data. Run thexcp verifycommand.[root@localhost]# ./xcp verify -acl4 -noid 10.63.5.56:/vol1 10.63.5.56:/vol2 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 3 scanned, 100% found (0 have data), 100% verified (data, attrs, mods, acls), 6 getacls, 6 v3perms, 2.90 KiB in (4.16 KiB/s), 2.94 KiB out (4.22 KiB/s), 0s.
If
verifyagain. If the source has new or updated data, then perform incremental updates. Run thexcp synccommand.[root@ root@localhost]# ./xcp sync -id id1 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 xcp: Index: {source: 10.63.5.56:/vol1, target: 10.63.5.56:/vol2} 3 reviewed, 3 checked at source, no changes, 3 reindexed, 25.6 KiB in (32.3 KiB/s), 23.3 KiB out (29.5 KiB/s), 0s.For this operation, the previous copy index name or number is required. -
copyoperation, run thexcp resumecommand.[root@localhost]# ./xcp resume -id id1 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 xcp: Index: {source: 10.63.5.56:/vol3, target: 10.63.5.56:/vol4} xcp: resume 'id1': Reviewing the incomplete index... xcp: diff 'id1': Found 0 completed directories and 8 in progress 39,899 reviewed, 1.64 MiB in (1.03 MiB/s), 14.6 KiB out (9.23 KiB/s), 1s. xcp: resume 'id1': Starting second pass for the in-progress directories... xcp: resume 'id1': Resuming the in-progress directories... xcp: resume 'id1': Resumed command: copy {-acl4: True} xcp: resume 'id1': Current options: {-id: 'id1'} xcp: resume 'id1': Merged options: {-acl4: True, -id: 'id1'} xcp: resume 'id1': Values marked with a * include operations before resume 86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (2.60 MiB/s), 78.4 KiB out (15.6 KiB/s), 5s 86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (0/s), 78.4 KiB out (0/s), 10s 1.00M scanned, 100% found (1M have data), 1M compared, 100% verified (data, attrs, mods, acls), 2.00M getacls, 202 v3perms, 1.00M same acls, 2.56 GiB in (2.76 MiB/s), 485 MiB out (524 KiB/s), 15m48s.After
Transitioning 7-Mode SMB storage to ONTAP for CIFS data
This section covers the step-by-step procedure for transitioning a source 7-Mode SMB share to an ONTAP system.
NetApp assumes that the 7-Mode and ONTAP systems are SMB licensed. The destination SVM is created, the source and destination SMB shares are exported, and XCP is installed and licensed. |
Scan the SMB shares for the files and directories.
C:\xcp>xcp scan -stats \\10.61.77.189\performance_SMB_home_dirs XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 == Maximum Values == Size Depth Namelen Dirsize 15.6MiB 2 8 200 == Average Values == Size Depth Namelen Dirsize 540KiB 2 7 81 == Top File Extensions == .txt .tmp 5601 2200 == Number of files == empty <8KiB 8-64KiB 64KiB-1MiB 1-10MiB 10-100MiB >100MiB 46 6301 700 302 200 252 == Space used == empty <8KiB 8-64KiB 64KiB-1MiB 1-10MiB 10-100MiB >100MiB 0 6.80MiB 8.04MiB 120MiB 251MiB 3.64GiB 0 == Directory entries == empty 1-10 10-100 100-1K 1K-10K >10k 18 1 77 1 == Depth == 0-5 6-10 11-15 16-20 21-100 >100 7898 == Modified == >1 year >1 month 1-31 days 1-24 hrs <1 hour <15 mins future 2167 56 322 5353 == Created == >1 year >1 month 1-31 days 1-24 hrs <1 hour <15 mins future 2171 54 373 5300 Total count: 7898 Directories: 97 Regular files: 7801 Symbolic links: Junctions: Special files: Total space for regular files: 4.02GiB Total space for directories: 0 Total space used: 4.02GiB 7,898 scanned, 0 errors, 0s
Copy the files (with or without ACL) from the source to the destination SMB share. The following example shows a copy with ACL.
C:\xcp>xcp copy -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 7,898 scanned, 0 errors, 0 skipped, 184 copied, 96.1MiB (19.2MiB/s), 5s 7,898 scanned, 0 errors, 0 skipped, 333 copied, 519MiB (84.7MiB/s), 10s 7,898 scanned, 0 errors, 0 skipped, 366 copied, 969MiB (89.9MiB/s), 15s 7,898 scanned, 0 errors, 0 skipped, 422 copied, 1.43GiB (99.8MiB/s), 20s 7,898 scanned, 0 errors, 0 skipped, 1,100 copied, 1.69GiB (52.9MiB/s), 25s 7,898 scanned, 0 errors, 0 skipped, 1,834 copied, 1.94GiB (50.4MiB/s), 30s 7,898 scanned, 0 errors, 0 skipped, 1,906 copied, 2.43GiB (100MiB/s), 35s 7,898 scanned, 0 errors, 0 skipped, 2,937 copied, 2.61GiB (36.6MiB/s), 40s 7,898 scanned, 0 errors, 0 skipped, 2,969 copied, 3.09GiB (100.0MiB/s), 45s 7,898 scanned, 0 errors, 0 skipped, 3,001 copied, 3.58GiB (100.0MiB/s), 50s 7,898 scanned, 0 errors, 0 skipped, 3,298 copied, 4.01GiB (88.0MiB/s), 55s 7,898 scanned, 0 errors, 0 skipped, 5,614 copied, 4.01GiB (679KiB/s), 1m0s 7,898 scanned, 0 errors, 0 skipped, 7,879 copied, 4.02GiB (445KiB/s), 1m5s 7,898 scanned, 0 errors, 0 skipped, 7,897 copied, 4.02GiB (63.2MiB/s), 1m5s
If there is no data aggregate, create a new one using the storage aggr createcommand. -
Sync the files on the source and destination.
C:\xcp>xcp sync -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 10,796 scanned, 4,002 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 5s 15,796 scanned, 8,038 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 10s 15,796 scanned, 8,505 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 15s 15,796 scanned, 8,707 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 20s 15,796 scanned, 8,730 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 25s 15,796 scanned, 8,749 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 30s 15,796 scanned, 8,765 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 35s 15,796 scanned, 8,786 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 40s 15,796 scanned, 8,956 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 45s 8 XCP v1.6 User Guide © 2020 NetApp, Inc. All rights reserved. Step Description 15,796 scanned, 9,320 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 50s 15,796 scanned, 9,339 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 55s 15,796 scanned, 9,363 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m0s 15,796 scanned, 10,019 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m5s 15,796 scanned, 10,042 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m10s 15,796 scanned, 10,059 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m15s 15,796 scanned, 10,075 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m20s 15,796 scanned, 10,091 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m25s 15,796 scanned, 10,108 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m30s 15,796 scanned, 10,929 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m35s 15,796 scanned, 12,443 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m40s 15,796 scanned, 13,963 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m45s 15,796 scanned, 15,488 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m50s 15,796 scanned, 15,796 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m51s
Verify that the files were copied correctly.
C:\xcp> xcp verify \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dir XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 8 compared, 8 same, 0 different, 0 missing, 5s 24 compared, 24 same, 0 different, 0 missing, 10s 41 compared, 41 same, 0 different, 0 missing, 15s 63 compared, 63 same, 0 different, 0 missing, 20s 86 compared, 86 same, 0 different, 0 missing, 25s 423 compared, 423 same, 0 different, 0 missing, 30s 691 compared, 691 same, 0 different, 0 missing, 35s 1,226 compared, 1,226 same, 0 different, 0 missing, 40s 1,524 compared, 1,524 same, 0 different, 0 missing, 45s 1,547 compared, 1,547 same, 0 different, 0 missing, 50s 1,564 compared, 1,564 same, 0 different, 0 missing, 55s 2,026 compared, 2,026 same, 0 different, 0 missing, 1m0s 2,045 compared, 2,045 same, 0 different, 0 missing, 1m5s 2,061 compared, 2,061 same, 0 different, 0 missing, 1m10s 2,081 compared, 2,081 same, 0 different, 0 missing, 1m15s 2,098 compared, 2,098 same, 0 different, 0 missing, 1m20s 2,116 compared, 2,116 same, 0 different, 0 missing, 1m25s 3,232 compared, 3,232 same, 0 different, 0 missing, 1m30s 4,817 compared, 4,817 same, 0 different, 0 missing, 1m35s 6,267 compared, 6,267 same, 0 different, 0 missing, 1m40s 7,844 compared, 7,844 same, 0 different, 0 missing, 1m45s 7,898 compared, 7,898 same, 0 different, 0 missing, 1m45s,cifs
