Introduction to automation for ONTAP and vSphere
PDF of this doc site
Artificial Intelligence
Public and Hybrid Cloud
Virtualization
Containers
Red Hat OpenShift with NetApp
Creating your file...
This page describes the benefits of automating base ONTAP functionality in a VMware vSphere environment.
VMware automation
Automation has been an integral part of managing VMware environments since the first days of VMware ESX. The ability to deploy infrastructure as code and extend practices to private cloud operations helps to alleviate concerns surrounding scale, flexibility, self-provisioning, and efficiency.
Automation can be organized into the following categories:
Virtual infrastructure deployment
Guest machine operations
Cloud operations
There are many options available to administrators with respect to automating their infrastructure. Whether through using native vSphere features such as Host Profiles or Customization Specifications for virtual machines to available APIs on the VMware software components, operating systems, and NetApp storage systems; there is significant documentation and guidance available.
Data ONTAP 8.0.1 and later supports certain VMware vSphere APIs for Array Integration (VAAI) features when the ESX host is running ESX 4.1 or later. VAAI is a set of APIs that enable communication between VMware vSphere ESXi hosts and storage devices. These features help offload operations from the ESX host to the storage system and increase network throughput. The ESX host enables the features automatically in the correct environment. You can determine the extent to which your system is using VAAI features by checking the statistics contained in the VAAI counters.
The most common starting point for automating the deployment of a VMware environment is provisioning block or file-based datastores. It is important to map out the requirements of the actual tasks prior to developing the corresponding automation.
For more information concerning the automation of VMware environments, see the following resources:
The NetApp Pub. NetApp configuration management and automation.
The Ansible Galaxy Community for VMware. A collection of Ansible resources for VMware.
VMware {code} Resources. Resources needed to design solutions for the software-defined data center, including forums, design standards, sample code, and developer tools.
