About role-based access control
Role-based access control (RBAC) lets you control who has access to SnapManager operations. RBAC allows administrators to manage groups of users by defining roles and assigning users to those roles. You might want to use SnapManager RBAC in environments where RBAC is already in place.
RBAC includes the following components:
Resources: Volumes and LUNs that hold the datafiles that make up your database.
Capabilities: Types of operations that can be performed on a resource.
Users: People to whom you grant capabilities.
Roles: A set of resources and capabilities allowed on resources. You assign a specific role to a user who should perform those capabilities.
You enable RBAC in SnapDrive. You can then configure specific capabilities per role in the Operations Manager Web graphical user interface or command-line interface. RBAC checks occur in the DataFabric Manager server.
The following table lists some roles and their typical tasks, as set in Operations Manager.
| Role | Typical tasks |
Oracle database administrator |
Server administrator |
Storage architect |
If RBAC is in use (meaning that Operations Manager is installed and RBAC is enabled in SnapDrive), the storage administrator needs to assign RBAC permissions on all of the volumes and storage systems for the database files.
