SnapManager Oracle
Configuring SnapDrive for UNIX for an active/active Veritas SFRAC environment
If you have included the host-cluster-sw-restore-warn parameter in snapdrive.conf and have assigned the value on, you must change the value to support the restore operation in the active/active Veritas Storage Foundation for Oracle RAC (SFRAC) environment.
When you are using the active/active Veritas Storage Foundation for Oracle RAC (SFRAC) environment, if the host-cluster-sw-restore-warn parameter is set to on, a warning message is displayed and the restore operation is stopped. If you want to perform the restore operation in an active/active Veritas SFRAC environment, you must set host-cluster-sw-restore-warn to off.
For information on snapdrive.conf, see SnapDrive documentation.
  1. Log in as the root user.
  2. Open the snapdrive.conf file by using a text editor.
  3. Change the value of host-cluster-sw-restore-warn to off.
After configuring, restart the SnapDrive for UNIX server.
