SnapManager Oracle
Supported storage types
SnapManager supports a wide range of storage types on both physical and virtual machines. You must verify support for your storage type before you install or upgrade SnapManager.
Machine Storage type
Physical server
  • NFS-connected volumes
  • FC-connected LUNs
  • iSCSI-connected LUNs
VMware ESX
  • NFS volumes connected directly to the guest system
  • RDM LUNs on the guest operating system
