SnapManager Oracle
The smo profile dump command
You can run the profile dump command to create the .jar file that contains diagnostic information about a profile.
Syntax
        smo profile dump
-profile profile_name
\[-quiet \| -verbose\]
  • -profile profile_name
    Specifies the profile for which you want to create the dump files. The profile contains the identifier of the database and other database information.
  • -quiet
    Displays only error messages in the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages in the console.
Example
The following example creates a dump for the profile SALES1:
smo profile dump -profile SALES1
Dump file created
Path:/userhomedirectory/.netapp/smo/3.3.0/smo_dump_SALES1_hostname.jar
