SnapManager Oracle
The smo clone delete command
You can run the clone delete command to delete a clone. You cannot delete a clone if the clone is use by any operation.
Syntax
        smo clone delete
-profile profile_name
\[-id guid \| -label clone_name\]
[-login
\[-username db_username -password db_password -port db_port\]
 \[-asminstance -asmusername asminstance_username  -asmpassword asminstance_password\]]
\[-syspassword syspassword\]
-force
\[-dump\]
\[-quiet \| -verbose\]
  • -profile profile_name
    Specifies the name of the profile containing the clone being deleted. The profile contains the identifier of the database and other database information.
  • -force
    Deletes the clone even if there are resources associated with the clone.
  • -id guid
    Specifies the GUID for the clone being deleted. The GUID is generated by SnapManager when you create a clone. You can use the smo clone list command to display the GUID for each clone.
  • -label name
    Specifies the label for the clone being deleted.
  • -asminstance
    Specifies the credentials that are used to log in to the Automatic Storage Management (ASM) instance.
  • -asmusername asminstance_username
    Specifies the user name used to log in to the ASM instance.
  • -asmpassword asminstance_password
    Specifies the password used to log in to ASM instance.
  • -syspassword syspassword
    Specifies the password for the sys privileged user.
    Note You must provide the password for the sys privileged user if the database credentials provided are not the same for sys privileged user.
  • -login
    Allows you to enter the database login details.
  • -username db_username
    Specifies the user name required to access the database.
  • -password db_password
    Specifies the password required to access the database.
  • -port db_port
    Specifies the TCP port number used to access the database that the profile describes.
  • -dump
    Specifies to collect the dump files after the clone delete operation.
  • -quiet
    Displays only error messages in the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages in the console.
Example
The following example deletes the clone:
smo clone delete -profile SALES1 -label SALES_May
Operation Id [8abc01ec0e79004b010e79006da60001] succeeded.
