The smo backup verify command
You can run the backup verify command to see if the backup is in a valid format for Oracle.
Syntax
smo backup verify
-profile profile_name
[-label backup_name \| \[-id guid\]
\[-retain \{-hourly \| -daily \| -weekly \| -monthly \| -unlimited\}\]
\[-force\]
\[-dump\]
\[-quiet \| -verbose\]
Specifies the profile for which you want to verify a backup. The profile contains the identifier of the database and other database information.
-id guid
Verifies the backup with the specified GUID. The GUID is generated by SnapManager when you create a backup. You can use the smo backup list command to display the GUID for each backup.
-label label_name
Verifies the backup with the specified label.
-dump
Collects the dump files after the successful or failed backup verify operation.
-force
Forces the database into the necessary state to perform the verify operation.
-quiet
Displays only error messages in the console. The default is to display error and warning messages.
-verbose
Displays error, warning, and informational messages in the console.
Example
The following is an example of verifying the backup:
smo backup verify -profile SALES1 -label full_backup_sales_May -quiet
DBVERIFY - Verification starting : FILE = +SMO_1_1161675083835/smo/datafile/data.277.582482539 ...
Related information
