Viewing and Managing Alerts from Monitors
Download PDF of this page
Cloud Insights displays alerts when monitored thresholds are exceeded.
Monitors and Alerting is available in Cloud Insights Standard Edition and higher. |
To view and manage alerts, do the following.
Navigate to the Alerts > Integration Alerts page.
A list of up to the most recent 1,000 alerts is displayed. You can sort this list on any field by clicking the column header for the field. The list displays the following information. Note that not all of these columns are displayed by default. You can select columns to display by clicking on the "gear" icon
Alert ID: System-generated unique alert ID
Triggered Time: The time at which the relevant Monitor triggered the alert
Current Severity (Active alerts tab): The current severity of the active alert
Top Severity (Resolved alerts tab); The maximum severity of the alert before it was resolved
Monitor: The monitor configured to trigger the alert
Triggered On: The object on which the monitored threshold was breached
Status: Current alert status, New or In Process
Active Status: Active or Resolved
Condition: The threshold condition that triggered the alert
Metric: The object’s metric on which the monitored threshold was breached
Monitor Status: Current status of the monitor that triggered the alert
You can manage an alert by clicking the menu to the right of the alert and choosing one of the following:
In Process to indicate that the alert is under investigation or otherwise needs to be kept open
Dismiss to remove the alert from the list of active alerts.
You can manage multiple alerts by selecting the checkbox to the left of each Alert and clicking Change Selected Alerts Status.
Clicking on an Alert ID opens the Alert Detail Page.
Alert Detail Page
The Alert Detail Page provides additional detail about the alert, including a Summary, an Expert View showing graphs related to the object’s data, any Related Assets, and Comments entered by alert investigators.
