Cable power for your E-Series storage system
You must connect each component's power supplies to separate power circuits.
Before you begin
You have confirmed that your location provides the necessary power.
The two power switches on the two shelf power supplies must be turned off.
About this task
The power source for your storage system must be able to accommodate the power requirements of the new drive shelf. For information about the power consumption for your storage system, see the Hardware Universe.
Step
Connect a power cable to each of the power supply units on your storage system.
Connect the two power cables for each shelf to different power distribution units (PDUs) in the cabinet or rack.
Power on both power supplies.
Depending on your storage system, the power supplies have power switches or there are no power switches and you must connect the power cables to power them on.
