E-Series storage systems
Reinstall the controller canister in an E2800 array
Contributors NetAppZacharyWambold netapp-driley netapp-jolieg
Reinstall the controller canister into the controller shelf after installing the new battery.
Steps
  1. Reinstall the cover on the controller canister by sliding the cover from back to front until the button clicks.
  2. Turn the controller canister over, so that the removable cover faces down.
  3. With the cam handle in the open position, slide the controller canister all the way into the controller shelf.
    24 drive controller reinstall
    (1) Controller canister
    (2) Cam handle
    60 drive controller reinstall
    (2) Cam handle
  4. Move the cam handle to the left to lock the controller canister in place.
  5. Reconnect all the cables.
  6. Go to Complete E2800 battery replacement.
