Complete the host protocol conversion for an EF300 or EF600 storage system
After you apply the feature pack key to convert the protocol, you must configure the host to use the appropriate protocol.
For step-by-step instructions, see the guide appropriate for your system:
Specific settings might vary. Check the NetApp Interoperability Matrix for specific instructions and additional recommended settings for your solution.
